CN0008
CN0008
    CHIPQUIK
    USB - MICRO AB ADAPTER BOARD
CN0008 数据手册
CN0008 Datasheet revision 1.0 www.Proto-Advantage.com USB - micro AB adapter board Product Highlights This adapter comes fully assembled with connector and pins installed. Specifications PCB dimensions: 10.16mm x 12.7mm x 1.6mm PCB construction: FR-4 UL94V-0 PCB operating temperature range (without connector): -40C to +130C PCB reflow maximum temperature (without connector): +260C PCB assembly standard: IPC-A-610 Class II 1 © 2007-2016 Proto Advantage
CN0008 价格&库存
很抱歉,暂时无法提供与“CN0008”相匹配的价格&库存,您可以联系我们找货
