3119
3119
    ADAFRUIT
    WASHER FLAT #6 FIBRE
3119 数据手册
HDMI Plug Breakout Board PRODUCT ID: 3119 Description Make your own custom HDMI cable or HDMI interface with ease, using this HDMI Plug to Breakout. You get a nice solid PCB with an HDMI plug and through hole pads that you can solder to assemble your own wiring jigs. You can add in some terminal blocks to make the wiring easier, or check out the HDMI Plug to Terminal Block Breakout which comes with them built in. If you just need a plain HDMI cable, we have plenty and it's less expensive to just buy a standard cable than DIY it. So, we recommend this adapter when you have some unusual setup or wiring needs like splicing off the I2C or power pins. Comes with one breakout and a clip-on housing. Technical Details Product Dimensions: 50.6mm x 25.0mm x 16.5mm / 2.0" x 1.0" x 0.6" Product Weight: 10.0g/0.4oz Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3119”相匹配的价格&库存,您可以联系我们找货
