3121
3121
    ADAFRUIT
    WASHER FLAT #6 FIBRE
3121 数据手册
Panel Mount HDMI Socket Breakout PRODUCT ID: 3121 Description Make your own custom HDMI input or HDMI interface with ease, using this HDMI Socket Breakout. You get a nice solid PCB with an HDMI socket that you can solder to assemble your own wiring jigs. You can add in some terminal blocks to make the wiring easier, or check out the HDMI Socket to Terminal Block Breakout which comes with them built in. We recommend this adapter when you have some unusual setup like wiring HDMI directly to your FPGA or wiring needs like splicing off the I2C or power pins. Comes with one breakout and a panel-mount housing. Technical Details Product Dimensions: 55.0mm x 49.6mm x 24.5mm / 2.2" x 2.0" x 1.0" Product Weight: 10.0g/0.4oz Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3121”相匹配的价格&库存,您可以联系我们找货
