3120
3120
    ADAFRUIT
    WASHER FLAT #6 FIBRE
3120 数据手册
Panel Mount HDMI Socket to Terminal Block Breakout PRODUCT ID: 3120 Description Make your own custom HDMI input or HDMI interface with ease, using this HDMI Socket to Terminal Block Breakout. You get a nice solid PCB with an HDMI socket and two strips of terminal blocks that you can use with stranded or solid core wire to assemble your own wiring jigs.  We recommend this adapter when you have some unusual setup like wiring HDMI directly to your FPGA or wiring needs like splicing off the I2C or power pins. Comes with one fully assembled breakout and a panel mounting. Technical Details Product Dimensions: 55.0mm x 49.6mm x 24.5mm / 2.2" x 2.0" x 1.0" Product Weight: 16.1g/0.6oz Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3120”相匹配的价格&库存,您可以联系我们找货
  • 1+52.164201+6.54150
库存:20
3120
    库存:20
