HDR127MET80M-G-V-SM
HDR127MET80M-G-V-SM
    CHIPQUIK
    SMD,P=1.27mm
    排针 间距:1.27mm SMT
HDR127MET80M-G-V-SM 数据手册
HDR127MET80M-G-V-SM Datasheet revision 1.1 www.Proto-Advantage.com 1.27 mm 80 pin Vertical Male Header Surface Mount Gold REF. A B C C1 E H H1 H2 L1 L2 W1 W2 MIN. DIMENSIONS mm TYP. MAX. MIN. 1.50 6.20 0.74 0.40 1.27 2.00 3.05 3.00 49.53 50.80 5.20 3.00 inches TYP. MAX. 0.050 1.950 2.000 L2 L1 C1 E W2 E C H1 A H H2 W1 1 Recommended PCB Layout E © 2007-2021 Proto Advantage™ B SPECIFICATIONS Plastic body construction: PA6T plastic (320°C melting point) Pin construction: Gold plated (brass pin, with 1um gold over 50um nickel) Operating temperature range: -40°C to +130°C Reflow maximum temperature: +260°C 2 © 2007-2021 Proto Advantage™
HDR127MET80M-G-V-SM 价格&库存
很抱歉,暂时无法提供与“HDR127MET80M-G-V-SM”相匹配的价格&库存,您可以联系我们找货
