HDR127MET80F-G-V-SM
HDR127MET80F-G-V-SM
    CHIPQUIK
    SMD,P=1.27mm
    排母 间距:1.27mm SMT
HDR127MET80F-G-V-SM 数据手册
HDR127MET80F-G-V-SM Datasheet revision 1.1 www.Proto-Advantage.com 1.27 mm 80 pin Vertical Female Header Surface Mount Gold REF. MIN. A B C C1 E H L1 L2 W1 W2 DIMENSIONS mm TYP. MAX. MIN. inches TYP. MAX. 2.20 5.40 0.74 0.48 1.27 3.40 49.53 51.20 4.80 3.10 W2 E C1 L1 L2 C A Recommended PCB Layout H W1 1 E © 2007-2021 Proto Advantage™ B SPECIFICATIONS Plastic body construction: PA6T plastic (320°C melting point) Pin construction: Gold plated (brass pin, with 1um gold over 50um nickel) Operating temperature range: -40°C to +130°C Reflow maximum temperature: +260°C 2 © 2007-2021 Proto Advantage™
HDR127MET80F-G-V-SM 价格&库存
很抱歉,暂时无法提供与“HDR127MET80F-G-V-SM”相匹配的价格&库存,您可以联系我们找货
