MPH100IMP40M-G-V-TH
MPH100IMP40M-G-V-TH
    CHIPQUIK
    0.1" 40 PIN MACHINE PIN VERTICAL
MPH100IMP40M-G-V-TH 数据手册
MPH100IMP40M-G-V-TH Datasheet revision 1.2 www.Proto-Advantage.com 0.1" 40 pin Machine Pin Vertical Male Header Through Hole Gold REF. C C1 C2 E H H1 H2 H3 H4 L1 L2 W2 1 MIN. DIMENSIONS mm TYP. MAX. MIN. 0.90 0.49 0.62 2.54 3.00 4.60 3.50 3.80 3.20 99.06 101.60 2.54 © 2007-2021 Proto Advantage™ inches TYP. 0.019 0.024 0.100 3.900 4.000 MAX. SPECIFICATIONS Plastic body construction: PA6T plastic (320°C melting point) Pin construction: Gold plated (brass pin, with 1um gold over 50um nickel) Operating temperature range: -40°C to +130°C Reflow maximum temperature: +260°C 2 © 2007-2021 Proto Advantage™
MPH100IMP40M-G-V-TH 价格&库存
很抱歉,暂时无法提供与“MPH100IMP40M-G-V-TH”相匹配的价格&库存,您可以联系我们找货
