HDR100IMP40M-G-V-TH
HDR100IMP40M-G-V-TH
    CHIPQUIK
    插件,P=2.54mm
    排针 间距:2.54mm 插件
HDR100IMP40M-G-V-TH 数据手册
HDR100IMP40M-G-V-TH Datasheet revision 1.1 www.Proto-Advantage.com 0.1" 40 pin Vertical Male Header Through Hole Gold REF. C C1 E H H1 H2 L1 L2 W2 MIN. DIMENSIONS mm TYP. MAX. MIN. 1.02 0.64 2.54 2.54 6.00 3.00 99.06 101.60 2.50 inches TYP. MAX. 0.100 3.900 4.000 L2 L1 C1 E H H1 Recommended PCB Hole Layout E H2 C W2 1 © 2007-2021 Proto Advantage™ SPECIFICATIONS Plastic body construction: PA6T plastic (320°C melting point) Pin construction: Gold plated (brass pin, with 1um gold over 50um nickel) Operating temperature range: -40°C to +130°C Reflow maximum temperature: +260°C 2 © 2007-2021 Proto Advantage™
HDR100IMP40M-G-V-TH 价格&库存
很抱歉,暂时无法提供与“HDR100IMP40M-G-V-TH”相匹配的价格&库存,您可以联系我们找货
