HDR100IMP40F-G-RA-TH
    CHIPQUIK
    弯插,P=2.54mm
    排母 间距:2.54mm 弯插
HDR100IMP40F-G-RA-TH 数据手册
HDR100IMP40F-G-RA-TH Datasheet revision 1.2 www.Proto-Advantage.com 0.1" 40 pin Right Angle Female Header Through Hole Gold REF. C C1 E H L1 L2 W1 W2 MIN. DIMENSIONS mm TYP. MAX. MIN. 1.02 0.65 2.54 8.50 99.06 102.10 3.20 2.50 inches TYP. MAX. 0.100 3.900 4.020 L2 L1 E W2 C1 Recommended PCB Hole Layout H E C W1 1 © 2007-2021 Proto Advantage™ SPECIFICATIONS Plastic body construction: PA6T plastic (320°C melting point) Pin construction: Gold plated (brass pin, with 1um gold over 50um nickel) Operating temperature range: -40°C to +130°C Reflow maximum temperature: +260°C 2 © 2007-2021 Proto Advantage™
HDR100IMP40F-G-RA-TH 价格&库存
很抱歉,暂时无法提供与“HDR100IMP40F-G-RA-TH”相匹配的价格&库存,您可以联系我们找货
