HDR100MET40F-G-RA-TH
    CHIPQUIK
    1.00 MM 40 PIN RIGHT ANGLE FEMAL
HDR100MET40F-G-RA-TH 数据手册
HDR100MET40F-G-RA-TH Datasheet revision 1.1 www.Proto-Advantage.com 1.00 mm 40 pin Right Angle Female Header Through Hole Gold REF. C C1 E H L1 L2 W1 W2 MIN. DIMENSIONS mm TYP. MAX. MIN. inches TYP. MAX. 0.50 0.32 1.00 2.00 39.00 40.40 2.40 1.50 L2 L1 E W2 C1 Recommended PCB Hole Layout H E C W1 1 © 2007-2021 Proto Advantage™ SPECIFICATIONS Plastic body construction: PA6T plastic (320°C melting point) Pin construction: Gold plated (brass pin, with 1um gold over 50um nickel) Operating temperature range: -40°C to +130°C Reflow maximum temperature: +260°C 2 © 2007-2021 Proto Advantage™
HDR100MET40F-G-RA-TH 价格&库存
很抱歉,暂时无法提供与“HDR100MET40F-G-RA-TH”相匹配的价格&库存,您可以联系我们找货
