HDR-ETD
HDR-ETD
    CHIPQUIK
    弯插,P=2.54mm
    排针 间距:2.54mm 弯插
HDR-ETD 数据手册
HDR-ETD Datasheet revision 1.1 www.Proto-Advantage.com 0.1" 40 pin Header Pair for PCB Edge to DIP Conversion DIMENSIONS REF. mm TYP. 1.02 0.64 7.62 2.54 2.54 8.55 3.00 11.09 99.06 101.60 1.60 MIN. C C1 D E H H1 H2 H3 L1 L2 T MAX. MIN. inches TYP. MAX. 0.300 0.100 3.900 4.000 T is the recommended PCB thickness. HDR-ETD is a set of two headers: one short pin (H1) + one long pin (H3). L2 L1 E C1 H H2 T Recommended PCB Hole Layout E H2 H3 E H1 E D 1 C © 2007-2021 Proto Advantage™ SPECIFICATIONS Plastic body construction: PA6T plastic (320°C melting point) Pin construction: Gold plated (brass pin, with 1um gold over 50um nickel) Operating temperature range: -40°C to +130°C Reflow maximum temperature: +260°C 2 © 2007-2021 Proto Advantage™
HDR-ETD 价格&库存
很抱歉,暂时无法提供与“HDR-ETD”相匹配的价格&库存,您可以联系我们找货
