MPH100IMP40M-G-V-SM
MPH100IMP40M-G-V-SM
    CHIPQUIK
    0.1" 40 PIN MACHINE PIN VERTICAL
MPH100IMP40M-G-V-SM 数据手册
MPH100IMP40M-G-V-SM Datasheet revision 1.1 www.Proto-Advantage.com 0.1" 40 pin Machine Pin Vertical Male Header SMT Gull-Wing REF. A B C C1 E H H1 H2 L1 L2 W1 W2 1 MIN. DIMENSIONS mm TYP. MAX. MIN. 5.40 3.00 1.00 0.45 2.54 3.00 3.50 4.80 99.06 101.60 4.36 2.54 © 2007-2021 Proto Advantage™ inches TYP. 0.018 0.100 MAX. SPECIFICATIONS Plastic body construction: PA6T plastic (320°C melting point) Pin construction: Gold plated (brass pin, with 1um gold over 50um nickel) Operating temperature range: -40°C to +130°C Reflow maximum temperature: +260°C 2 © 2007-2021 Proto Advantage™
MPH100IMP40M-G-V-SM 价格&库存
很抱歉,暂时无法提供与“MPH100IMP40M-G-V-SM”相匹配的价格&库存,您可以联系我们找货
