T44-1/C
T44-1/C
    VECTOR
    TERMINAL WW MINIWRAP .042" GOLD
T44-1/C 数据手册
CATALOG 128_CATALOG 128.qxd 4/25/2014 7:16 AM Page 77 PCB Accessories Spring Insertion Tool Anvils and Dies Insertion/Staking Methods for Terminals P158 Spring Impact Insertion Tools Provide An Easy Method of Manually Installing: Terminals Pins Wrap Posts Eyelets Fig. 3 Backup Method Wrap Post Only D10 - Die www.vectorelect.com Die Part No. Anvil Part No. Die/Anvil Intended For D7-2 D7-2 N/A N/A Insertion Insertion D7-2 N/A Insertion D11 D11 D7-2 D7-4 D7-2 D8 D7 D17 D17 D10 D7-4 D7 N/A N/A N/A D7-4 D8 D7-4 D7 N/A Insertion Staking Insertion Insertion Insertion Insertion Staking Insertion Staking Insertion D10 N/A Insertion .042” 1/16” 1/16” 3/32” 1/16” 3/32” 1/16” 1/16” 1/16” 1/16” 1/16” 1/16” 1/16” 1/16” 1/16” 1/16” 3/32” 1/16” 3/32” 1/16” D9 N/A Insertion .055” .042” .042” 1/8” 1/16” 1/16” D19 D19 D20 N/A A19 A19 Insertion Insertion Insertion Terminal Reference Description Req’d Hole Dia. K24 K30, K36 Inbord Pin Inbord Pin .042” .042” K31 Inbord Pin .042” T44Series T44Series T46-2 T46-3 T46-5 T49Series T49Series T68Series T68Series R30Series Sq. Pin Sq. Pin Terminal Terminal Terminal Sq. Pin Sq. Pin Sq. Pin Sq. Pin Socket Pin .042” .042” .042” .042” .042” .042” .042” .042” .042” .055” R31Series Socket Pin .055” R32Series Socket Pin R52Series T125 T126 Socket Pin Terminal Terminal Bd Thk. 800-423-5659 Tools D9 - Die This spring actuated terminal insertion tool with interchangeable die points provides a happy compromise between slow manual tools and expensive machines for installing terminals in Vectorbord . The P158 impact tool with associated die points has an adjustable spring which supplies installation impact force. Since the impact is not governed by human strength, each terminal is easily and consistently installed with the optimum pressure. Also available are anvils. 77
T44-1/C 价格&库存
很抱歉,暂时无法提供与“T44-1/C”相匹配的价格&库存,您可以联系我们找货
