DATA SHEET
MECHANICAL DATA
a
63.5 ± 3.0
b
6.4 +3.0 / -0
c
76.0 ± 3.0
d
13.5 max. {04}
e
24.0 max. {04}
Pin 1
Primary (Red)
Pin 2
Pin 3
Secondary High Voltage (White)
Common (Blue)
Remarks
1.
Primary wire uses 26 GA. STR. Teflon acc. to UL style 1704.
Common wire uses 26 GA. STR. Teflon acc. to UL style 1704.
HV wire uses 24 GA. STR. Teflon acc. to UL style 1704. {02}
The enameled wire must be 0 UEW and insulation level must be Class H for Primary, and Class F for Secondary. {04}
2.
Casing acc. to UL94V-0. Material: PPO {01}
3.
Bobbin acc. to UL94V-0. Material: PPS {01}
4.
Potting Resin acc. to UL94V-0. Material: Resin 3300-SY {01}
5.
Filling is done with vacuum. {02}
6.
Operating temperature
7.
{01}{02}
8.
RoHS compliance
-30°C to +105°C {01}
NAME
DATE
DEPARTMENT
DRAWN
MICHAEL LI
20.11.2009
COE
05
-2/05x1
24.09.14
MAUNG TT
CHECKED
MICHAEL LI
20.11.2009
COE
04
-1&2/04X4
21.02.14
MAUNG TT
DESCRIPTION
03
-2/03x1
17.01.14
MAUNG TT
02
-1/02X3
02.08.13
MAUNG TT
01
-1&2/01X4
11.01.13
MAUNG TT
REV
CHANGE
DATE
NAME
ZS 1324-24V-LUL-1(H)
{01}
8 TRACTOR ROAD
SINGAPORE 627969
PAGE 1 OF 2
DATA SHEET
OPERATING DATA
Item
Primary
Secondary
Resistance
238 ± 15% mohm
265 ± 15% ohm {03}{04}
Primary Voltage, Uzp
400 V
Primary Capacitance, Cz
0.3 µF
Polarity of 1 peak
1 Peak Negative
Secondary Voltage, Uz
24 ± 3 kV {05}
Inductance @ 1 kHz
35 ± 10 µH
90 ± 10 mH
st
st
Typical Waveform:
Unloaded high voltage output
10 µs/div
NAME
DATE
10 kV/div
DEPARTMENT
DRAWN
MICHAEL LI
20.11.2009
COE
CHECKED
MICHAEL LI
20.11.2009
COE
{01}
DESCRIPTION
8 TRACTOR ROAD
SINGAPORE 627969
PAGE 2 OF 2
很抱歉,暂时无法提供与“ZS1324-24VLUL1(H)”相匹配的价格&库存,您可以联系我们找货
