1808-FX-225-RC
1808-FX-225-RC
    CRITICALLINK
    1808-FX-225-RC
1808-FX-225-RC 数据手册
Critical Link, LLC www.criticallink.com MitySOM MitySOM-1808 Processor Card 5-MAR-2014 FEATURES  TI AM1808 ARM9 Application Processor -      456 MHz ARM926EJ-S MPU  16 KB L1 Program Cache  16 KB L1 Data Cache  8 KB Internal RAM  64 KB boot ROM  JTAG Emulation/Debug Up To 256 MB mDDR2 CPU RAM Up To 512 MB Parallel NAND FLASH 8 MB SPI based NOR FLASH Integrated Power Management Standard SO-DIMM-200 Interface - 10/100 EMAC MII / RMII / MDIO - 2 UARTS - 2 McBSPs, 2 SPI, 2HPI - 2 USB Ports - Video, LCD Output - Camera/Video Input - MMC/SD - SATA - ePWM, eCAP - EMIFA - Single 3.3V Power Supply (actual size) APPLICATIONS  Industrial Automation  Industrial Instrumentation  Embedded Control Processing  Embedded User Interfaces  Test and Measurement  Medical Devices BENEFITS  Rapid Development / Deployment  Multiple Connectivity and Interface Options  Rich User Interfaces  High System Integration  High Level OS Support - Linux - QNX 6.4 - Windows Embedded CE Ready - ThreadX Real Time OS DESCRIPTION The MitySOM-1808 is a highly configurable, very small form-factor processor card that features a Texas Instruments AM1808 456 MHz ARM Applications Processor, FLASH (NAND, and NOR) and mDDR2 RAM memory subsystems. The MitySOM-1808 provides a complete and flexible CPU infrastructure necessary for the most demanding embedded applications development. The AM1808 includes an ARM926EJ-S micro-processor unit (MPU) capable of running the rich software applications programming interfaces (APIs) expected by modern system designers. The ARM architecture supports several operating systems, including Linux, QNX and Windows XP embedded. Linux drivers are available for all interfaces. 1 Copyright © 2013, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com MitySOM MitySOM-1808 Processor Card 5-MAR-2014 1.2V 8MB NOR Flash (SPI interface) For uBoot bootloader Up To 256MB mDDR Memory 16-bit wide 1.8V Power Management 3.3V System Clocks JTAG Header JTAG/Emulator Texas Instruments AM1808 456-MHz ARM926EJ-S ™ RISC MPU GND Up To 512MB NAND Flash 8-bit wide For root FFS 3.3 V EMIFA (16-bit) Boot Config Boot Config VPIF I/O MMCSD 1 EMAC RMII uPP UHPI LCD Resets & RTC SATA USB 0,1 Timers eCAP eHRPWM I2C 0,1 McASP SPI 0,1 McBSP 0,1 MMCSD 0 UART 0,1,2 EMAC MII/MDIO (Many pins are multiplexed between peripherals) SO-DIMM-200 (DDR2 Connector) Figure 1 MitySOM-1808 Block Diagram Figure 1 provides a top level block diagram of the MitySOM-1808 processor card. As shown in the figure, the primary interface to the MitySOM-1808 is through a standard SO-DIMM-200 card edge interface. The interface provides power, synchronous serial connectivity, and a rich set of interfaces available for application defined interfacing. Details of the SO-DIMM-200 connector interface are included in the SO-DIMM-200 Interface Description, below. AM1808 mDDR2 Memory Interface The AM1808 includes a dedicated DDR2 SDRAM memory interface. The MitySOM1808 includes up to 256 MB of mDDR2 RAM integrated with the AM1808 processor. The bus interface is capable of burst transfer rates of 600 MB / second. Note that the OSCIN frequency to the AM1808 processor on the module is 24MHz. AM1808 SPI NOR FLASH Interface The MitySOM-1808 includes 8 MB of SPI NOR FLASH. This FLASH memory is intended to store a factory provided bootloader, and typically a compressed image of a Linux kernel for the ARM core processor. 2 Copyright © 2013, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com MitySOM MitySOM-1808 Processor Card 5-MAR-2014 EMIFA / NAND FLASH Interface The Asynchronous External Memory Interface (EMIFA) interface available on the AM1808 is available on the SO-DIMM-200 connector. The EMIFA interface includes 3 chip select spaces. The EMIF interface supports multiple data width transfers and bus wait state configurations based on chip select space. 8, and 16 bit data word sizes may be used. Up to 512 MB of on-board NAND FLASH memory is connected to the AM1808 using the EMIFA bus. The FLASH memory is 8 bits wide and is connected to the third chip select line of the EMIFA (CE1). The FLASH memory is typically used to store the following types of data: - ARM Linux / Windows Embedded CE / QNX embedded root file-system - runtime ARM software - runtime application data (non-volatile storage) AM1808 Camera and Video Interfaces The AM1808 includes an optional video port I/O interface commonly used to drive LCD screens as well as a camera input interface. These interfaces have been routed directly to the SO-DIMM-200 connector. Debug Interface The JTAG signals for the AM1808 processor have been brought out to a Hirose header that is intended for use with an available Critical Link breakout adapter. This header can be removed for production units; please contact your Critical Link representative for details. This adapter is not included with individual modules but is included with each Critical Link Development Kit that is ordered. If an adapter, Critical Link (CL) part number 80000286, is needed please contact your Critical Link representative. Software and Application Development Support Users of the MitySOM-1808 are encouraged to develop applications using the MitySOM1808 software development kit provided by Critical Link LLC. The development kit includes an implementation of an OpenEmbedded board support package providing an Angstrom based Linux distribution and compatible gcc compiler tool-chain with debugger. Growth Options The MitySOM-1808 has been designed to support several upgrade options. These options include various speed grades, memory configurations, and operating temperature specifications including commercial and industrial temperature ranges. The available options are listed in the section below containing ordering information. For additional ordering information and details regarding these options, or to inquire about a particular configuration not listed below, please contact a Critical Link sales representative. 3 Copyright © 2013, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com MitySOM MitySOM-1808 Processor Card 5-MAR-2014 ABSOLUTE MAXIMUM RATINGS OPERATING CONDITIONS If Military/Aerospace specified cards are required, please contact the Critical Link Sales Office or unit Distributors for availability and specifications. Ambient Temperature Range Commercial Ambient Temperature Range Industrial Humidity Maximum Supply Voltage, Vcc 3.5 V 0oC to 70oC -40oC to 85oC 0 to 95% Non-condensing Contact Critical Link for Details MIL-STD-810F Storage Temperature Range Shock, Z-Axis Shock, X/Y-Axis -65 to 80C ±10 g ±10 g SO-DIMM-200 Interface Description The primary interface connector for the MitySOM-1808 is the SO-DIMM card edge interface which contains 4 classes of signals: Power (PWR) Dedicated signals mapped to the AM1808 device (D) Dedicated signals when NAND memory is populated on the module (D*) Multi-function signals mapped to the AM1808 device (M) Table 1 contains a summary of the MitySOM-1808 pin mapping. Pin 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 Ball K14 J1 J2 L1 L2 P16 P18 P19 N19 M18 M19 K18 - Type PWR PWR PWR PWR PWR D D D D D D D D D D D D D PWR PWR I/O I O O I I I I/O I/O O I/O I/O O - Table 1 SO-DIMM Pin-Out Signal Pin Ball +3.3 V in 2 +3.3 V in 4 +3.3 V in 6 GND 8 GND 10 RESET_IN# 12 SATA_TX_P 14 A4 SATA_TX_N 16 A3 SATA_RX_P 18 A2 SATA_RX_N 20 A1 USB0_ID 22 B4 USB1_D_N 24 B1 USB1_D_P 26 B2 USB0_VBUS 28 B3 USB0_D_N 30 C2 USB0_D_P 32 C3 USB0_DRVVBUS 34 C4 3V RTC Battery 36 C5 +3.3 V in 38 +3.3 V in 40 - 4 Type PWR PWR PWR PWR PWR D M M M M M M M M M M M M PWR PWR I/O I I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O - Signal +3.3 V in +3.3 V in +3.3 V in GND GND EXT_BOOT# GP0_7 GP0_10 GP0_11 GP0_15 GP0_6 GP0_14 GP0_12 GP0_5 GP0_13 GP0_1 GP0_4 GP0_3 +3.3 V in +3.3 V in Copyright © 2013, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com Pin 41 43 45 47 491 51 53 552 572 59 Ball H17 G17 H16 G19 F18 G16 G18 F16 Type PWR D D D D M D D D M I/O I/O I/O I/O I/O I/O I/O I/O I/O 61 F17 M I/O 63 65 67 69 71 73 75 77 79 81 83 85 87 89 91 93 95 F19 E18 E16 D17 D19 C17 D16 E17 D18 C19 C18 C16 A18 B15 C15 PWR M M M M M M M M M M PWR M M M D* M O I O I/O I I I I I I I I O O O 97 A15 M O 99 C14 M 101 D15 103 MitySOM MitySOM-1808 Processor Card 5-MAR-2014 Signal GND SPI1_MISO SPI1_MOSI SPI1_ENA SPI1_CLK SPI1_SCS[1] Reserved I2C0_SCL I2C0_SDA UART2_TXD I2C1_SDA UART2_RXD I2C1_SCL GND UART1_TXD UART1_RXD MDIO_CLK MDIO_D MII_RXCLK MII_RXDV MII_RXD[0] MII_RXD[1] MII_RXD[2] MII_RXD[3] GND MII_CRS MII_RXER EMA_CS[0] EMA_OE EMA_BA[0] / Pin 42 44 46 48 50 52 54 56 58 60 Ball D4 E4 F4 D5 A12 C11 E12 B11 E11 Type PWR M M M M M M M M M I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O Signal GND GP0_2 GP0_0 GP0_8 GP0_9 MMCSD0_DAT[7] MMCSD0_DAT[6] MMCSD0_DAT[5] MMCSD0_DAT[4] MMCSD0_DAT[3] / 62 C10 M I/O MMCSD0_DAT[2] 64 66 68 70 72 74 76 78 80 82 84 86 88 90 92 94 96 A11 B10 A10 E9 D3 E3 E2 E1 F3 C1 D1 W15 V15 U18 PWR M M M M M M M M M M PWR M D M M M I/O I/O I/O O I O O O O O I I/O I I/O EMA_BA[1] 98 V16 M I/O O EMA_A[0] 100 R14 M I/O D* O EMA_A[1] 102 W16 M I/O B14 D* O EMA_A[2] 104 V17 M I/O 105 D14 M O EMA_A[3] 106 W17 M I/O 107 109 A14 PWR M O GND EMA_A[4] 108 110 W18 PWR M I/O 111 C13 M O EMA_A[5] 112 W19 M I/O 113 115 117 119 121 E13 B13 A13 D12 C12 M M M M M O O O O O EMA_A[6] EMA_A[7] EMA_A[8] EMA_A[9] EMA_A[10] 114 116 118 120 122 V18 V19 U16 U19 T16 M M M M M I/O I/O I/O I/O I/O GND MMCSD0_DAT[1] MMCSD0_DAT[0] MMCSD0_CMD MMCSD0_CLK MII_TXCLK MII_TXD[3] MII_TXD[2] MII_TXD[1] MII_TXD[0] MII_TXEN GND MII_COL NC UPP_CHA_START VP_CLKIN1 UPP_D[15] / RMII_TXD[1] UPP_D[14] / RMII_TXD[0] UPP_D[13] / RMII_TXEN UPP_D[12] / RMII_RXD[1] UPP_D[11] / RMII_RXD[0] UPP_D[10] / RMII_RXER GND UPP_D[9] / RMII_REF_CLK UPP_D[8] / RMII_CRS_DV UPP_D[7] UPP_D[6] UPP_CHA_ENABLE UPP_D[5] UPP_D[4] 5 Copyright © 2013, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com Pin 123 125 127 129 131 133 135 137 139 141 143 145 147 149 151 153 155 157 159 161 163 165 167 169 1713 173 175 177 179 181 183 185 187 189 191 193 195 1974 1994 Ball B12 D13 D11 E6 C7 B6 A6 D6 A7 D9 E10 D7 C6 E7 B5 E8 B8 A8 C9 C8 A5 D8 B7 B9 A9 A16 B17 F9 B16 T17 J3 K4 F2 D10 A17 Type M M M PWR D* D* D* D* D* D* D* D* D* D* PWR D* D* D* D* D* D* M M M M PWR D* M M M M M D M M M PWR M D* I/O O O O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O O O O O O O O O O O O I O O O O MitySOM MitySOM-1808 Processor Card 5-MAR-2014 Signal EMA_A[11] EMA_A[12] EMA_A[13] GND EMA_D[15] EMA_D[14] EMA_D[13] EMA_D[12] EMA_D[11] EMA_D[10] EMA_D[9] EMA_D[8] EMA_D[7] EMA_D[6] GND EMA_D[5] EMA_D[4] EMA_D[3] EMA_D[2] EMA_D[1] EMA_D[0] EMA_WEN_DQM[0] EMA_WEN_DQM[1] EMA_SDCKE EMA_CLK GND EMA_WE EMA_CAS EMA_RAS EMA_CS[2] EMA_CS[4] EMA_CS[5] RESET_OUT VP_CLKIN3 VP_CLKOUT3 LCD_MCLK GND EMA_A_RW EMA_CS[3] Pin 124 126 128 130 132 134 136 138 140 142 144 146 148 150 152 154 156 158 160 162 164 166 168 170 172 174 176 178 180 182 184 186 188 190 192 194 196 198 200 Ball R18 R19 T15 R15 P17 U17 J4 K3 H3 G3 G2 G1 W14 P4 R3 R2 R1 T3 T2 T1 U3 U2 U1 G4 H4 V3 F1 V2 V1 W3 W2 W1 R5 B184 B194 Type M M M PWR M M M M M M M M M M PWR M M M M M M M M M M PWR M M M M M M M M M M PWR D* M I/O I/O I/O I/O I/O I/O I/O I/O O I I/O I/O I/O I I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O O O I/O O I/O I/O I/O I/O I/O O I I Signal UPP_D[3] UPP_D[2] UPP_CHA_WAIT GND UPP_D[1] UPP_D[0] UPP_CHA_CLK UPP_CHB_ENABLE VP_CLKOUT2 VP_CLKIN2 UPP_CHB_WAIT UPP_CHB_START UPP_CHB_CLK VP_CLKIN0 GND LCD_D[15] LCD_D[14] LCD_D[13] LCD_D[12] LCD_D[11] LCD_D[10] LCD_D[9] LCD_D[8] LCD_D[7] LCD_D[6] GND LCD_VSYNC LCD_HSYNC LCD_D[5] LCD_PCLK LCD_D[4] LCD_D[3] LCD_D[2] LCD_D[1] LCD_D[0] LCD_AC_ENB_CS GND EMA_WAIT[0] EMA_WAIT[1] Note 1: Pin 49, SPI1_CLK, has a 100K Ohm pull-down resistor on the module Note 2: Pins 55 and 57 have 4.70K pull-up resistors on the module Note 3: Pin 171, EMA_CLK, has a 49.9 Ohm resistor in series with the signal on the module Note 4: Pins 197, 198, 199 and 200 have 1.00K Ohm resistors in series with the signals on the module The signal group description for the above pins is included in Table 2 6 Copyright © 2013, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com MitySOM MitySOM-1808 Processor Card 5-MAR-2014 Table 2 Signal Group Description Signal / Group 3.3 V in EXT_BOOT# RESET_IN# Type N/A I I SPI1_* I/O MII_* I/O MDIO_DAT MDIO_CLK I/O GP0_* I/O SATA_TX_P SATA_TX_N O SATA_RX_P SATA_RX_N I GND N/A Description 3.3 volt input power referenced to GND. Bootstrap configuration pin. Pull low to configure booting from external UART1. Manual Reset. When pulled to GND for a minimum of 1 usec, resets the processor. Serial Peripheral Interface 1 pins. These pins are direct connects to the corresponding SPI1_* pins on the AM1808 processor. The SPI1_* function pins are multiplexed with other functions. These include PWM, Timers, UARTs, I2C0, and GPIO. For details please refer to the AM1808 processor specifications. Media Independent Interface (Ethernet) pins. These pins are direct connects to the corresponding MII_* pins on the AM1808 processor. The MII_* function pins are multiplexed with other functions. These include SPI0, PWM, Timers, UART0, MCBSP, MCASP, and GPIO. For details please refer to the AM1808 processor specifications. MII/RMII Management Interface pins. The MDIO_CLK and MDIO_DAT signals are direct connects to the corresponding MDIO_* signals on the AM1808 processor. The MDIO_* function pins are multiplexed with other functions. These include SPI0 and Timer functions. For details please refer to the AM1808 processor specifications. General Purpose / multiplexed pins. These pins are direct connects to the corresponding GP0[*] pins on the AM1808 processor. The include support for the McASP, general purpose I/O, UART flow control, and McBSP 1. For details please refer to the AM1808 processor specifications. Serial ATA Controller Transmit pins. These pins are direct connects to the corresponding SATA_TX_* pins on the AM1808 processor. For details please refer to the AM1808 processor specifications. Serial ATA Controller Receive pins. These pins are direct connects to the corresponding SATA_RX_* pins on the AM1808 processor. For details please refer to the AM1808 processor specifications. System Digital Ground. 7 Copyright © 2013, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com Signal / Group EMA_* MitySOM MitySOM-1808 Processor Card 5-MAR-2014 Type I/O UPP_* I/O RMII_* I/O LCD_* I/O VP_* I/O RESET_OUT I/O USB0_*, USB1_* I/O Description EMIF-A pins. These pins are direct connects to the corresponding EMA_* pins on the AM1808 processor. Alternatively, these pins can be configured as GPIOs for modules that do not have NAND memory present. For details please refer to the AM1808 processor specifications. Note that pins 197, 198, 199 and 200 have 1.00K Ohm resistors in series with the signals on the module. Universal Parallel Port pins. These pins are direct connects to the corresponding UPP_* pins on the AM1808 processor. The UPP_* function pins are multiplexed with other functions. These include RMII, VP_DIN, MMCSD1, and GPIO. For details please refer to the AM1808 processor specifications. Reduced Media Independent Interface pins. These pins are direct connects to the corresponding RMII_* pins on the AM1808 processor. The RMII_* function pins are multiplexed with other functions. These include UPP and VP_DIN. For details please refer to the AM1808 processor specifications. Liquid Crystal Display pins. These pins are direct connects to the corresponding LCD_* pins on the AM1808 processor. The LCD_* function pins are multiplexed with other functions. These include VP_DOUT, UPP, MMCSD1, and GPIO. For details please refer to the AM1808 processor specifications. Video Port In/Out. These pins are direct connects to the corresponding VP_* pins on the AM1808 processor. The VP_* function pins are multiplexed with other functions. These include UPP, MMCSD1, and GPIO. For details please refer to the AM1808 processor specifications. Reset Output pin. This pin is a direct connect to the RESET_OUT pin on the AM1808 processor. This pin can also be configured as a GPIO. For details please refer to the AM1808 processor specifications. Universal Serial Bus 0 / 1 pins. These pins are direct connects to the corresponding USB_* pins on the AM1808 processor. For details please refer to the AM1808 processor specifications. 8 Copyright © 2013, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com MitySOM MitySOM-1808 Processor Card 5-MAR-2014 DEBUG INTERFACE Below is the pin-out for the Hirose 31 pin header (DF9-31P-1V(32)) that interfaces with an available adapter board, CL part number 80-000286, to debug the AM1808. Debug Interface Connector Description (J2) Pin 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 I/O - GND GND GND GND GND GND GND GND GND GND GND GND GND GND GND GND Table 3 AM1808 Hirose Connector Signal Pin I/O Signal 2 O OMAP EMU1 4 O OMAP EMU0 6 I OMAP TCK 8 O OMAP RTCK 10 O OMAP TDO 12 OMAP VCC / 3.3V 14 I OMAP TDI 16 I OMAP TRST 18 I OMAP TMS 20 GND 22 NC FPGA VREF / VCCAUX 24 NC FPGA TMS 26 NC FPGA TCK 28 NC FPGA TDO 30 NC FPGA TDI 9 Copyright © 2013, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com MitySOM MitySOM-1808 Processor Card 5-MAR-2014 ELECTRICAL CHARACTERISTICS Table 4: Electrical Characteristics Parameter Conditions Min Symbol V33 I33 I33-max FCPU FEMIF Typ Max Voltage supply, 3.3 volt input. 3.2 3.3 Quiescent Current draw, 3.3 volt input 170 230 Max current draw, positive 3.3 volt input. 300 CPU internal clock Frequency (PLL output) 25 300 EMIF bus frequency 100 1. Power utilization of the MitySOM-1808 is heavily dependant on end-user application. include: ARM CPU PLL configuration, and external DDR2 RAM utilization. Units 3.4 Volts 250 mA TBS mA 456 MHz MHz Major factors ORDERING INFORMATION The following table lists the standard module configurations. For shipping status, availability, and lead time of these or other configurations please contact your Critical Link representative. Model 1808-FX-225-RC 1808-DX-225-RI Table 5: Standard Model Numbers NOR ARM Speed NAND Flash Flash 456 MHz 8MB 256MB 375 MHz 8MB 256MB 10 RAM 128MB 128MB Operating Temp 0oC to 70o C -40oC to 85o C Copyright © 2013, Critical Link LLC Specifications Subject to Change Critical Link, LLC www.criticallink.com MitySOM MitySOM-1808 Processor Card 5-MAR-2014 MECHANICAL INTERFACE A mechanical outline of the MitySOM-1808 is illustrated in Figure 2, below. Figure 2 MitySOM-1808 Mechanical Outline REVISION HISTORY Date 7-JAN-2011 11-FEB-2011 12-JUL-2011 11-DEC-2012 27-MAR-2013 5-MAR-2014 Change Description Initial Release Update DDR Speed to support 150 MHz clocking. Update NAND to indicate 8 bit data width. Update block diagram accordingly. Update Debug Header information, added MIL-STD-810F and Up To notation for RAM and NAND Added AM1808 processor pins with notes about on module resistors for specific pins as well as the OSCIN frequency. Update MitySOM product name. 11 Copyright © 2013, Critical Link LLC Specifications Subject to Change
1808-FX-225-RC 价格&库存
很抱歉,暂时无法提供与“1808-FX-225-RC”相匹配的价格&库存,您可以联系我们找货
