19031074A
19031074A
    COMAIRROTRON
    插件
    19031074A
19031074A 数据手册
SPECIFICATIONS (RoHS Compliant) Model Number: Part Number: GL12B4 19031074A August 11, 2005 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic Additional Features: = 12 vdc = 6 - 14 vdc = 1.30 amps = 3.00 amps = 16.0 watts = 3200 rpm = Ball = 150 CFM = 53.6 dBA Brushless DC Motor Polarity Protected Locked Rotor Protection Automatic Restart Capability Operating Temperature Storage Temperature Termination: 0.110” wide Terminals Construction: Agency Approvals: Venturi: Die Cast Zinc, Black Propeller: Plastic, Black, UL 94V-0 UL, CE Life Expectancy: This fan is designed for continuous duty life of 75,000 hours at 40C. -10C to 70C -40 C to 85C Polarity Labeled
19031074A 价格&库存
很抱歉,暂时无法提供与“19031074A”相匹配的价格&库存,您可以联系我们找货
