19031075A
19031075A
    COMAIRROTRON
    插件
    19031075A
19031075A 数据手册
SPECIFICATIONS (RoHS Compliant) Model Number: Part Number: GL24B4 19031075A August 31, 2005 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic Additional Features: = 24 vdc = 12 - 28 vdc = 0.625 amps = 1.350 amps = 15.0 watts = 3250 rpm = Ball = 150 CFM = 53.6 dBA Construction: Venturi: Die Cast Zinc, Black Propeller: Plastic, Black, UL 94V-0 Life Expectancy: This fan is designed for continuous duty life of 82,500 hours at 50C. Brushless DC Motor Automatic Restart Capability Polarity Protected Locked Rotor Protection Operating Temperature: Storage Temperature: -10C to 70C -40C to 85C Termination: 0.110” wide Terminals Agency Approvals: UL, CE Polarity Labeled
19031075A 价格&库存
很抱歉,暂时无法提供与“19031075A”相匹配的价格&库存,您可以联系我们找货
