19040396A
19040396A
    COMAIRROTRON
    插件
    19040396A
19040396A 数据手册
SPECIFICATIONS Model Number: Part Number: CD24R7X 040396 Preliminary Data August 15, 2005 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 24 vdc = 12 - 28 vdc = 1.200 amps = 3.000 amps = 29.0 watts = 1650 rpm = Ball = 550 cfm = 47.5 dBA Construction: Venturi: Die-Cast Aluminum, Black Propeller: Polycarbonate, Black, UL 94V-0 Life Expectancy: This fan is designed for continuous duty life of 60,000 hours at 40°C. Agency Approvals: UL, CSA, TUV Additional Features: Brushless DC Motor Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: Storage Temperature: Programmable Tachometer: Output: IC: Vcc: Pulses Per Revolution: Isolated: Termination: -10°C to 70°C -40°C to 85°C Open Collector 20 mA Max. 28 Vdc Max 2 No 12” Lead wires, 22 AWG, UL 1061 Red – Power Black – Return Blue/White – Tachometer Yellow - Program
19040396A 价格&库存
很抱歉,暂时无法提供与“19040396A”相匹配的价格&库存,您可以联系我们找货
