833202B04800
833202B04800
    COMAIRROTRON
    TO220
    833202B04800
833202B04800 数据手册
Board Level Heat Sinks P/N: 833202B04800 TO-220 PRODUCT SPECIFICATIONS • No Hardware Device Attachment • Constant Spring Force Tension • Vertical Mounting via Solderable Tabs • RoHS Compliant 0 400 600 800 1000 20 80 16 60 12 40 8 20 4 0 0 0 CUSTOMIZED HEATSINKS 200 100 1 2 3 Heat Dissipated - Watts • Specialized Tabs, Plating • Specialized Body Configurations • Contact Applications Engineering COMAIR ROTRON, INC 8929 Terman Court, San Diego, CA 92121 Ph (858) 348-6200 Fax (858) 566-4577 E-mail: sales@comairrotron.com, Web: www.comairrotron.com 4 5 Thermal Resistance - oC/ Watt (Mounting Surface to Ambient) FEATURES & BENEFITS Air Velocity - LFM Temp Rise Above Ambient -oC (Mounting Surface) • Devices: TO-220 • Size: 10.0 x 21.2 x 19.0 mm • Material: Aluminum, 0.8 mm Thick • Type: Stamped • IC Mounting: Integrated Spring • PCB Mounting: Solderable Tabs • Finish: Black Anodized • Package: Bulk
833202B04800 价格&库存
很抱歉,暂时无法提供与“833202B04800”相匹配的价格&库存,您可以联系我们找货
