Board Level
Heat Sinks
P/N: 833202B03700
• Constant Spring Force Tension
• Vertical Mounting via Solderable Tabs
• RoHS Compliant
400
600
800
1000
16
60
12
40
8
CUSTOMIZED HEATSINKS
200
1
2
3
Heat Dissipated - Watts
• Specialized Tabs, Plating
• Specialized Body Configurations
• Contact Applications Engineering
COMAIR ROTRON, INC
8929 Terman Court, San Diego, CA 92121
Ph (858) 348-6200 Fax (858) 566-4577
E-mail: sales@comairrotron.com,
Web: www.comairrotron.com
4
5
(Mounting Surface to Ambient)
• No Hardware Device Attachment
Thermal Resistance - oC/ Watt
FEATURES & BENEFITS
Air Velocity - LFM
Temp Rise Above Ambient -oC
(Mounting Surface)
• Devices: TO-220
• Size: 10.0 x 21.2 x 19.0 mm
• Material: Aluminum, 0.8 mm Thick
• Type: Stamped
• IC Mounting: Integrated Spring
• PCB Mounting: Solderable Step Tabs
• Finish: Black Anodized
• Package: Bulk
TO-220
PRODUCT SPECIFICATIONS
很抱歉,暂时无法提供与“833202B03700”相匹配的价格&库存,您可以联系我们找货
