6455-JE-3X5-RC
6455-JE-3X5-RC
    CRITICALLINK
    6455-JE-3X5-RC
6455-JE-3X5-RC 数据手册
Critical Link, LLC www.CriticalLink.com www.MityDSP.com MityDSP-Pro MityDSP-Pro Processor Card 13 March 2012 FEATURES  TI TMS320C645x DSP - 720 MHz, 1 GHz, & 1.2 GHz options - 1 MB cache or 2 MB cache options - Integrated 10/100/1000 EMAC - 2 Integrated McBSPs - JTAG Emulation/Debug  On-Board Xilinx Spartan3 FPGA - XC3S2000 & XC3S4000 options - 300 MHz Clock Logic - JTAG Interface/Debug  On-Board 10/100 Ethernet PHY connected to DSP’s EMAC  128 MB CPU DDR2 SDRAM  64 MB FPGA DDR1 SDRAM  16 MB NOR FLASH  SO-DIMM-200 Interface - 140 FPGA User I/O Pins - 2 McBSP Interfaces - I2C Interface - 10/100 Ethernet Interface - 3.3V Power Interface  Expansion I/O Connector - DSP Rapid IO Interface - DSP PCI I/O Interface - DSP Gigabit Ethernet Interface (RGMII) to an external PHY APPLICATIONS  Embedded Instrumentation  Rapid Development / Deployment  Embedded Digital Signal Processing  Real-time Audio / Video Processing (3.25” x 2.7” - actual size) DESCRIPTION The MityDSP-Pro is a highly configurable, high performance, small form-factor processor card that features a Texas Instruments TMS320C645x Digital Signal Processor (DSP) tightly integrated with a Xilinx Spartan3 Field Programmable Gate Array (FPGA), FLASH and DDR1/DDR2 SDRAM memory subsystems. Both the DSP and the FGPA are capable of loading/executing programs and logic images developed by end users. The MityDSP-Pro provides a complete digital processing infrastructure necessary for embedded applications development. Users of the MityDSP-Pro are encouraged to develop applications and FPGA firmware using the MityDSP hardware and software development kit provided by Critical Link. The development kit includes API libraries compatible with the TI Code Composer Studio compiler as well as FPGA netlist components compatible with the Xilinx ISE FPGA synthesis/implementation tools. The libraries provide the necessary functions needed to configure the MityDSP-Pro, program standalone MityDSP embedded applications, and interface with the various hardware components on the board. In addition, the libraries include several interface “cores” – FPGA and DSP software 1 Copyright © 2007-2012, Critical Link LLC Critical Link, LLC www.CriticalLink.com www.MityDSP.com MityDSP-Pro MityDSP-Pro Processor Card 13 March 2012 modules designed to interface with various data converter modules (ADCs, DACs, LCD interfaces, etc) – as well as bootloading and FLASH programming utilities. Figure 1 provides a top-level block diagram of the MityDSP-Pro processor card. As shown in the figure, the primary interface to the MityDSP-Pro is through a standard SODIMM-200 card edge interface. The interface provides 3.3V power, configuration control, Ethernet connectivity, inter-integrated circuit (I2C) connectivity, synchronous serial connectivity, and 140 pins of configurable FPGA I/O for application-defined interfacing. Details of the SO-DIMM connector interface are included in the SO-DIMM200 Interface Description, below. Debug Header Gigabit Ethernet RGMII 50 MHz Clock JTAG/Emulator NOR Flash 16 MB JTAG HPI / PCI Rapid I/O 4 pair Tx/Rx (6455 Option) Expansion Header Board Identity Bank Control CE3 DDR2 128MB 32-bit wide Texas Instruments TMS320C645x DSP EMIF (32-bit) Xilinx Spartan 3 FPGA CE2,CE4,CE5 DDR 64 MB 16-bit wide INT4, INT5, INT6 1.2 1.5 1.8 2.5 Power Regulation GND 3.3 V Bank 7 I/O Bank 2 I/O Bank 1 I/O 3.3 Bank 0 I/O Bank 7 3.3V Bank 2 3.3V Bank 0 3.3V McBSP 2 I2C Bank 1 3.3V FPGA Bank 3.3V Power Boot Config Logic McBSP 1 10/100 Ethernet PHY MII/MDIO Interface SO-DIMM-200 Figure 1: MityDSP-Pro Block Diagram 2 Copyright © 2007-2012, Critical Link LLC Critical Link, LLC www.CriticalLink.com www.MityDSP.com MityDSP-Pro MityDSP-Pro Processor Card 13 March 2012 FPGA Bank I/O The MityDSP-Pro provides 140 lines of FPGA I/O directly to the SO-DIMM-200 card edge interface. The 140 lines of FPGA I/O are distributed across 4 banks of the FPGA. These I/O lines and their associated logic are completely configurable within the FPGA. With the Xilinx Spartan3 family of FPGA, each bank may be configured to operate on a different electrical interface standard based on input voltage and termination configurations. The MityDSP-Pro provides, for each of the four externally accessible FPGA banks, a power supply pin (VCCO_N) to allow the bank to be powered to 2.5V or 3.3V. The following table outlines the various electrical interface standards that are possible on the MityDSP-Pro: Table 1: MityDSP-Pro FPGA Available I/O Standards I/O Standard 2.5V LVDS with 100 ohm DCI termation 2.5V LVDS without DCI termination 2.5V CMOS (pull-up/down options in FPGA) 3.3V CMOS (pull-up/down options in FPGA) Bank Voltage 2.5V 2.5V 2.5V 3.3V VCCO_N pin Open or 2.5V supply Open or 2.5V supply Open or 2.5V supply 3.3V supply For complete details regarding hardware bank voltage configuration please refer to the SO-DIMM-200 Interface description and the appropriate Spartan3 manuals from Xilinx. Integrated DSP Communications Modules The C6454 processor includes several on-chip communications modules. The MityDSPPro design provides access to the several of the modules through the SO-DIMM-200 card edge interface. The Ethernet MAC MII/MDIO interface on the DSP has been integrated with an onboard Ethernet PHY device. The Tx/Rx line-level signals of the PHY device are brought to the SO-DIMM-200 connector. In order to leverage the Ethernet interface, application boards need only supply appropriate Ethernet magnetics, and the RJ-45 Ethernet connector, which are often available as a single component. The MityDSP software developer’s kit includes a software driver and port of the LwIP TCP/IP protocol stack for use with the Ethernet interface. The DSP’s Gigabit Ethernet capability is accessible via the expansion I/O connector on the bottom side of the MityDSP-Pro module. The EMAC’s Reduced Gigabit Medium Independent Interface (RGMII) is available on this connector for connection to a PHY device on the end application board. The signals are separate from the MII signals routed to the on-board 10/100 PHY. Although the same EMAC module within the DSP services both sets of signals, only one Ethernet interface can be used at a time. The inter-integrated circuit (I2C) signals have been routed between the DSP, FPGA, and the SO-DIMM-200 interface. Communication is allowed between any combination of DSP, FPGA, and user board devices. TI provides several I2C interface libraries for 3 Copyright © 2007-2012, Critical Link LLC Critical Link, LLC www.CriticalLink.com www.MityDSP.com MityDSP-Pro MityDSP-Pro Processor Card 13 March 2012 integration with various data acquisition modules. The MityDSP development kit also contains modules for implementing I2C communication using the FPGA connection. In addition, the I2C interface may be used to boot the DSP processor (see the SO-DIMM200 interface description for details on MityDSP-Pro boot configuration). The DSP also includes two multi-channel buffered serial ports (McBSPs) which have been routed directly to the SO-DIMM-200 interface. Both Critical Link (as part of the MityDSP development kit) and TI provide several McBSP interface libraries for integration with various data acquisition modules. EMIF Interface The C645x DSP and the Spartan3 FPGA are connected using the DSP External Memory Interface (EMIFA). The EMIFA interface includes 4 chip-select spaces. The EMIFA interface supports multiple data width transfers and bus wait state configurations based on chip select space. 8, 16, 32, and 64 bit data word sizes may be used. Three of the four chip-select lines are reserved for the FPGA interface. The MityDSP-Pro also includes lines between the FPGA and the DSP for the purposes of generating interrupts. In addition to the FPGA, 16 MB of on-board NOR FLASH memory is also connected to the DSP using the EMIF. The FLASH memory is connected to fourth chip-select line of the EMIF (CE3). The FLASH memory is typically used to store the following types of data:  secondary bootloader DSP software  secondary bootloader FPGA image  application DSP software  application FPGA images  application data (non-volatile storage) The DSP EMIF interface is only capable of addressing 4 MB of data on the EMIF interface. In order to provide access to the remaining 12 MB of FLASH memory, the upper address lines of the FLASH are controlled by Bank Control logic. Upon reset the Bank Control Logic defaults to bank zero for bootloading support. Following bootloading, the bank control logic is controlled by the FPGA. Refer to the MityDSP User’s Guide for more information on bank control logic. System Memory The C6454 includes a 32 KB level-1 program (L1P) cache/SRAM, a 32 KB level-1 data (L1D) cache/SRAM, and a 1 MB level-2 (L2) cache/SRAM. The C6455 doubles the L2 cache/SRAM to 2MB. All types of cache/SRAM may be split into various amounts of cache and SRAM. Refer to TI’s datasheets for specific details on configuring the cache/SRAM memory blocks. For main DSP software program and runtime data storage, a dedicated 128 MB of DDR2 memory is available via the DDR2 control interface on the DSP. The memory is 32 bits 4 Copyright © 2007-2012, Critical Link LLC Critical Link, LLC www.CriticalLink.com www.MityDSP.com MityDSP-Pro MityDSP-Pro Processor Card 13 March 2012 wide and is capable of running at 250 MHz providing a burst throughput of 2 GB per second to the processor. For the FPGA, a separate 64 MB of DDR1 memory is provided. The memory interface is 16 bits wide and is capable of running at 125 MHz providing a burst throughput of 500 MB per second to the FPGA. Common uses for the FPGA memory include custom data collection systems, video frame buffers, and MicroBlaze program storage. Debug Interface Both the JTAG interface signals for the FPGA and the JTAG and emulator signals for the C645x processor have been brought out to a connector/header for use with in-circuit debugging. The JTAG chains are separate on the interface. With an appropriate breakout cable, the interface will support the use of standard Xilinx Platform JTAG cable programming and the Spectrum Digital processor emulator (or equivalent). Details of the pin-outs for the debug header are included in the Debug Interface Description below. Expansion Interface For system expansion, the MityDSP-Pro also provides a low profile Hirose FX8-100SSV connector interface that may be used to access the Host-Port-Interface (HPI), Peripheral-Component-Interconnect (PCI), and Gigabit Ethernet MAC ports of the C645x bus. In addition, four lanes of transmit and receive Rapid I/O data lines (and associated clocks) are also provided with the C6455 processor option. Module Options The MityDSP-Pro has been designed to support several upgrade options. These include a selection of 3 CPU speeds with a combination of 2 FPGA types. If you do not see a combination in Table 6 that meets your needs please contact a Critical Link sales representative. 5 Copyright © 2007-2012, Critical Link LLC Critical Link, LLC www.CriticalLink.com www.MityDSP.com MityDSP-Pro MityDSP-Pro Processor Card 13 March 2012 Example Application The figure below illustrates an example application utilizing the MityDSP-Pro processor card. The example application is a 6-way signal beamformer for use in a radar system. The card is required to capture 6 channels of IF signal data, downconvert the data to baseband, sum the signals together with the input channels and data provided from upstream processors, and send the results to downstream processing. Embedded Application Card (Hex-Beam Former) Strobes / Timing 60 Msps 60 Msps 60 Msps ADC, 14 bit 60 Msps ADC, 14 bit 60 ADC, Msps 14 bit 60 ADC, Msps 14 bit ADC, 14 bit ADC, 14 bit Status Indicators IF Data 5 Debug USB-B 7 84 USB PHY Signal Signal Signal Conditioning Signal Conditioning Conditioning Signal Conditioning Signal Conditioning Conditioning 10 LVDS Output, Baseband to Downstream processors 10 LVDS Input, Baseband from Upstream Processors MityDSP-Pro Control RJ-45 24 Bit 5 sps ADC (McBSP) Ethernet Magnetics Temperature Sensors Figure 2: Typical MityDSP-Pro Application In the example application, a designer leverages three of the four FPGA I/O banks as 3.3V CMOS interface and is able to integrate 6 14-bit ADC circuits directly to the MityDSP-Pro FPGA as well as various strobe signals and status indicators. The fourth bank is reserved for LVDS signaling and is used to receive and transmit data from upstream and downstream processors. The user is able to utilize the McBSP interface of the MityDSP-Pro to capture on-board temperature data for health monitoring. In addition, an Ethernet interface and a USB interface are added to provide debug and status and control information to external control units. Within the MityDSP-Pro, the user is able to utilize the FPGA multiply accumulator engines and programmable logic to capture, baseband, and integrate each of the ADC channels on the main board. The TI processor can be used to compute complex coefficients used in the beamforming process and provide the command and control interface for the entire card. With the application, the user needs only focus on the details of the application specific problems at hand: e.g., developing the appropriate signal conditioning and application software and firmware. The framework for the processing and interconnects is completely designed with the integration of the MityDSP-Pro. 6 Copyright © 2007-2012, Critical Link LLC Critical Link, LLC www.CriticalLink.com www.MityDSP.com MityDSP-Pro MityDSP-Pro Processor Card 13 March 2012 ABSOLUTE MAXIMUM RATINGS OPERATING CONDITIONS If Military/Aerospace specified cards are required, please contact the Critical Link Sales Office or unit Distributors for availability and specifications. Commercial Temperature Range Industrial Temperature Range Humidity Maximum Supply Voltage, Vcc Storage Temperature Range Shock, Z-Axis Shock, X/Y-Axis 3.4 V 0 to 70C -40 to +85C 0 to 95% Non-condensing -65 to 80C ±10 g ±10 g ELECTRICAL CHARACTERISTICS Symbol Vcc Icc Icc-max Parameter Conditions Voltage supply, 3.3 volt input. Quiescent Current draw, 3.3 volt input Max current draw, positive 3.3 volt input. Min Typ Max Units 3.3 1.5 1.7 3.4 3 3.5 Volts Amps Amps 10 0 TBD KHz Volts Volts Clock Frequency, Digital Inputs Update period, digital inputs Clock Frequency, Digital Output LVDS clk entering deserializer Update period, digital outputs 1. 25 1280 50 25 1280 20 / 68 MHz ns MHz 20 14.7 / 50 ns Power utilization of the MityDSP-Pro is heavily dependant on end-user application. Major factors include: CPU PLL configuration, FPGA utilization, and external SDRAM utilization. SO-DIMM-200 Interface Description The primary interface connector for the MityDSP-Pro is the SO-DIMM-200 card edge interface. Table 2 lists every pin on the SO-DIMM-200 main interface connector. Table 3 describes the function of each group of signals on the main interface connector. 7 Copyright © 2007-2012, Critical Link LLC Critical Link, LLC www.CriticalLink.com www.MityDSP.com Pin 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 49 51 53 55 57 59 61 63 65 67 69 71 73 75 77 79 81 83 85 87 89 91 93 95 97 99 MityDSP-Pro MityDSP-Pro Processor Card 13 March 2012 Table 2: SO-DIMM-200 Pin-Out Signal FPGA Bank Signal 3.3 V 3.3 V 3.3 V 3.3 V 3.3 V 3.3 V GND GND GND GND MRESET# BOOT_MODE ETH_TD_P RS232_TXD ETH_TD_N RS232_RXD ETH_RD_P RS232_RTS ETH_RD_N RS232_CTS FPGA_RSV1 SCL FPGA_RSV2 SDA CLKR0 CLKR1 CLKX0 CLKX1 DR0 DR1 DX0 DX1 FSR0 FSR1 FSX0 FSX1 VCCO_2 VCCO_1 VCCO_0 VCCO_7 GND GND ODD1_P.N26 2 EVN1_P.N22 ODD1_N.N25 2 EVN1_N.N21 ODD2_P.M26 2 EVN2_P.N24 ODD2_N.M25 2 EVN2_N.N23 ODD3_P.M22 2 EVN3_P.M24 ODD3_N.M21 2 EVN3_N.L23 ODD4_P.L26 2 EVN4_P.K24 ODD4_N.L25 2 EVN4_N.K23 ODD5_P.K26 2 EVN5_P.J25 ODD5_N.K25 2 EVN5_N.J24 GND GND ODD6_P.K22 2 EVN6_P.H24 ODD6_N.K21 2 EVN6_N.H23 ODD7_P.H26 2 EVN7_P.J23 ODD7_N.H25 2 EVN7_N.J22 ODD8_P.J21 2 EVN8_P.H21 ODD8_N.H22 2 EVN8_N.H20 ODD9_P.D26 2 EVN9_P.E24 ODD9_N.D25 2 EVN9_N.E23 ODD10_P.F21 1 EVN10_P.C23 ODD10_N.E21 1 EVN10_N.B23 GND GND ODD11_P.E20 1 EVN11_P.C22 ODD11_N.D20 1 EVN11_N.B22 ODD12_P.B21 1 EVN12_P.D21 ODD12_N.A21 1 EVN12_N.C21 ODD13_P.B20 1 EVN13_P.G18 ODD13_N.A20 1 EVN13_N.F18 ODD14_P.B19 1 EVN14_P.G17 8 Pin 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 62 64 66 68 70 72 74 76 78 80 82 84 86 88 90 92 94 96 98 100 Copyright © 2007-2012, Critical Link LLC Critical Link, LLC www.CriticalLink.com www.MityDSP.com Pin 101 103 105 107 109 111 113 115 117 119 121 123 125 127 129 131 133 135 137 139 141 143 145 147 149 151 153 155 157 159 161 163 165 167 169 171 173 175 177 179 181 183 185 187 189 191 193 195 197 199 MityDSP-Pro MityDSP-Pro Processor Card 13 March 2012 Signal ODD14_N.A19 ODD15_P.F16 ODD15_N.E16 GND ODD16_P.B15 ODD16_N.A15 ODD17_P.C14 ODD17_N.B14 ODD18_P.A13 ODD18_N.B13 ODD19_P.A12 ODD19_N.B12 ODD20_P.H13 ODD20_N.G12 GND ODD21_P.F11 ODD21_N.G11 ODD22_P.A8 ODD22_N.B8 ODD23_P.A7 ODD23_N.B7 ODD24_P.D7 ODD24_N.E7 ODD25_P.D6 ODD25_N.E6 GND ODD26_P.A4 ODD26_N.B4 ODD27_P.D2 ODD27_N.D1 ODD28_P.H5 ODD28_N.J6 ODD29_P.K6 ODD29_N.K5 ODD30_P.G2 ODD30_N.G1 GND ODD31_P.H2 ODD31_N.H1 ODD32_P.K2 ODD32_N.K1 ODD33_P.L2 ODD33_N.L1 ODD34_P.M2 ODD34_N.M1 ODD35_P.N2 ODD35_N.N1 GND 3.3V 3.3V FPGA Bank 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 - 9 Signal EVN14_N.F17 EVN15_P.E17 EVN15_N.D17 GND EVN16_P.F15 EVN16_N.E15 EVN17_P.E14 EVN17_N.D14 EVN18_P.F13 EVN18_N.G13 EVN19_P.C13 EVN19_N.D13 EVN20_P.E12 EVN20_N.F12 GND EVN21_P.D11 EVN21_N.E11 EVN22_P.C10 EVN22_N.D10 EVN23_P.E10 EVN23_N.F10 EVN24_P.F9 EVN24_N.G9 EVN25_P.B6 EVN25_N.C6 GND EVN26_P.B5 EVN26_N.C5 EVN27_P.J5 EVN27_N.J4 EVN28_P.H4 EVN28_N.H3 EVN29_P.J3 EVN29_N.J2 EVN30_P.K4 EVN30_N.K3 GND EVN31_P.L6 EVN31_N.L5 EVN32_P.M5 EVN32_N.M6 EVN33_P.L4 EVN33_N.M3 EVN34_P.N4 EVN34_N.N3 EVN35_P.N6 EVN35_N.N5 GND 3.3V 3.3V Pin 102 104 106 108 110 112 114 116 118 120 122 124 126 128 130 132 134 136 138 140 142 144 146 148 150 152 154 156 158 160 162 164 166 168 170 172 174 176 178 180 182 184 186 188 190 192 194 196 198 200 Copyright © 2007-2012, Critical Link LLC Critical Link, LLC www.CriticalLink.com www.MityDSP.com MityDSP-Pro MityDSP-Pro Processor Card 13 March 2012 Table 3: Signal Group Description Signal / Group 3.3 V MRESET# I/O N/A I ETH_TD_P / N ETH_RD_P / N O I FPGA_RSV1 / 2 IO CLKR0 / 1 CLKX0 / 1 DR0 / 1 DX0 / 1 FSR0 / 1 BOOT_MODE IO SCL, SDA I/O GND ODDXX_P/N.YYY EVNXX_P/N.YYY N/A IO VCCO_N N/A I Description 3.3 volt reference input power referenced to GND. Manual Reset. Pulled-up on the MityDSP-Pro module. When driven to GND for a minimum of 1 us, a module-wide reset is triggered. Can be tied into system system-wide reset and power monitoring circuitry. Ethernet Transmit Data & Receive Data link lines. These pairs of signals are connected to the onboard 10/100 Ethernet PHY connected to the DSP EMAC. These pairs should be routed through appropriate 1:1 magnetics prior to exposure to an RJ-45 type connector interface. Reserved for Ethernet RJ45 Link & Activity LED signals, driven by the on-board 10/100 PHY. Can also be used as general purpose FPGA I/O. These pins are direct connects to the corresponding McBSP port-0 / port-1 pins on the C645x DSP. For further interface information, please refer to the TMS645x McBSP Users Guide and Data Sheets. Boot Mode Selection. Reserved for future use. Do not connect. These pins are connected to the I2C interface on the C645x DSP, and also to FPGA pins. For further interface information, please refer to the TMS320C645x I2C Users Guide and Data Sheets. System Digital Ground. FPGA General Purpose I/O pin. FPGA I/O pins have been routed to the MityDSP connector in pairs denoted ODDXX (odd pin side of connector) or EVNXX (even pin side of connector). When configured for differential termination the pairs should be used according to the _P (positive) or _N (negative) extension. The YYY portion of the name corresponds to the FPGA pin location mapped to the signal. FPGA Banks 0, 1, 2, and 7 Voltage configuration. Leave disconnected for 2.5V bank logic (LVCMOS25 or LVDS25). Connect to 3.3V power supply for 3.3V bank logic (LVCMOS33 or LVTTL). PCB trace must be capable of providing a minimum of 200 mA. 10 Copyright © 2007-2012, Critical Link LLC Critical Link, LLC www.CriticalLink.com www.MityDSP.com MityDSP-Pro MityDSP-Pro Processor Card 13 March 2012 Debug Interface Description The debug interface connector pin-out is specified in the table below. Table 4: Debug Connector Pin-Out Pin Signal Signal Pin 1 DSP_EMU0 DSP_TMS 2 3 DSP_EMU1 DSP_TDI 4 5 3.3V DSP_TDO 6 7 GND DSP_TCK 8 9 GND DSP_TRST# 10 11 FPGA_TDI FPGA_TMS 12 13 FPGA_TCK FPGA_TDO 14 15 GND 2.5V 16 Expansion Interface Description The Expansion Interface pin-out is described in the table below. Table 5: Expansion Interface Pin-Out Pin Signal Signal Pin 1 GND GND 2 3 RIORX0_N RIOTX0_P 4 5 RIORX0_P RIOTX0_N 6 7 RIORX1_P RIOTX1_P 8 9 RIORX1_N RIOTX1_N 10 11 RIORX2_N RIOTX2_N 12 13 RIORX2_P RIOTX2_P 14 15 RIORX3_P RIOTX3_N 16 17 RIORX3_N RIOTX3_P 18 19 RIOCLK_N GND 20 21 RIOCLK_P HPI_WIDTH 22 23 GND PCI_AD27 24 25 PCI_EEAI PCI_AD1 26 27 PCI66 PCI_AD30 28 29 PCI_EN PCI_AD0 30 31 PCI_AD11 PCI_AD4 32 33 PCI_AD10 PCI_AD22 34 35 PCI_AD3 PCI_AD25 36 37 PCI_AD5 PCI_AD8 38 39 PCI_AD29 PCI_AD21 40 41 PCI_AD23 PCI_AD13 42 43 PCI_AD7 PCI_AD2 44 45 PCI_AD9 PCI_AD19 46 47 PCI_AD28 PCI_AD15 48 49 PCI_AD31 PCI_ERR# 50 51 PCI_AD16 PCI_AD17 52 53 PCI_AD6 PCI_AD18 54 55 PCI_AD14 PCI_STOP# 56 57 GND PCI_AD26 58 59 PCI_CLK PCI_AD20 60 61 GND PCI_CBE2# 62 11 Copyright © 2007-2012, Critical Link LLC Critical Link, LLC www.CriticalLink.com www.MityDSP.com MityDSP-Pro MityDSP-Pro Processor Card 13 March 2012 Pin 63 65 67 69 71 73 75 77 79 81 83 85 87 89 91 93 95 97 99 Signal PCI_AD12 PCI_FRAME# PCI_DEVSEL# PCI_PAR PCI_IDSEL PCI_IRDY# PCI_GNT# PCI_INTA# PCI_TRDY# GND RGMDCLK RGMDIO RGRXD3 RGRXD2 RGRXD1 RGRXD0 RGRXCTL RGRXC GND 12 Signal PCI_AD24 PCI_SERR# PCI_RST# PCI_CBE1# PCI_CBE0# PCI_CBE3# PCI_REQ# MAC_SEL RGMII_VREF GND RGREFCLK GND RGTXD3 RGTXD2 RGTXD1 RGTXD0 RGTXCTL RGTXC GND Pin 64 66 68 70 72 74 76 78 80 82 84 86 88 90 92 94 96 98 100 Copyright © 2007-2012, Critical Link LLC Critical Link, LLC www.CriticalLink.com www.MityDSP.com MityDSP-Pro MityDSP-Pro Processor Card 13 March 2012 ORDERING INFORMATION The following table lists the orderable module configurations. For shipping status, availability, and lead time of these or other configurations please contact your Critical Link representative. Model CPU Speed 6455-JE-3X5-RC 6455-IE-3X5-RI 6454-GD-3X5-RC 6454-ID-3X5-RI 1.2 GHz 1.0 GHz 720 MHz 1.0 GHz Table 6: Orderable Model Numbers L2 NOR CPU DDR2 FPGA CPU Flash RAM Cache XC3S4000 2 MB 16MB 128MB XC3S4000 2 MB 16MB 128MB XC3S2000 1 MB 16MB 128MB XC3S2000 1 MB 16MB 128MB FPGA DDR1 RAM Operating Temp 64MB 64MB 64MB 64MB 0oC to 70o C -40oC to 85o C 0oC to 70o C -40oC to 85o C MECHANICAL INTERFACE A mechanical outline of the MityDSP-Pro is illustrated below. Figure 3: Dimensions 3.25" x 2.7" 13 Copyright © 2007-2012, Critical Link LLC Critical Link, LLC www.CriticalLink.com www.MityDSP.com MityDSP-Pro MityDSP-Pro Processor Card 13 March 2012 REVISION HISTORY Date 13-MAR-2012 Change Description Update available model numbers and add rev history 14 Copyright © 2007-2012, Critical Link LLC
6455-JE-3X5-RC 价格&库存
很抱歉,暂时无法提供与“6455-JE-3X5-RC”相匹配的价格&库存,您可以联系我们找货
