19032744A
19032744A
    COMAIRROTRON
    插件
    19032744A
19032744A 数据手册
SPECIFICATIONS Model Number: Part Number: CR08024HB257004 19032744A Version: 01 Jan 22, 2017 Static Pressure Inches of Water Mechanical Drawing: 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0.00 0 5 10 15 20 25 30 35 CFM Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Running Power Average Speed Bearings Air Flow Static Pressure: Acoustic Additional Features: = 24 vdc = 21.6 – 26.4 vdc = 0.10 amps = 2.40 watts = 3010 RPM = Ball = 37.241 CFM = 0.157 Inch H2O = 35.8 dBA Construction: Venturi: Glass Filled polyester (P.B.T) Propeller: Glass Filled polyester (P.B.T) Life Expectancy: This fan is designed for continuous duty life of 70,000 hours at 40°C, 65% RH. Brushless DC Motor Locked Rotor Protection Polarity Protected Operating Temperature: Storage Temperature: -10°C to 70°C -40°C to 70°C Termination: 300 mm Lead-wires, 24AWG, UL 1007 Red - Power (+) Black - Return (-) Agency Approvals: CE 40
19032744A 价格&库存
很抱歉,暂时无法提供与“19032744A”相匹配的价格&库存,您可以联系我们找货
