19028268A
19028268A
    COMAIRROTRON
    插件
    19028268A
19028268A 数据手册
SPECIFICATIONS RoHS Model Number: Part Number: SU2B1 19028268A Version: 08 Dec 29, 2017 Mechanical Drawing: Motor: Normal Voltage = 115 VAC Operating Voltage Range = 99~121VAC Operating Frequency = 50/60Hz Rated Current = 0.14/0.13A Input Power = 15/13Watt Average Speed = 2380/2800RPM Bearings = Ball Airflow = 24/31CFM (Measuring at zero static pressure) Static Pressure = 0.13/0.17’’ H2O (Measuring at zero air flow) Noise Level = 30/32 dB(A) Net Weight = 260 gram. Construction: Venturi: High quality magnesium alloy die-casting frame with ED coating and powder coating, Black. Propeller: Magnesium alloy with ED coating, Black Life Expectancy: This fan is designed for continuous duty life of 62,000 hours at 70C Additional Features: Insulation Resistance: 100MΩ or more at 500 V megger. Dielectric strength: 2 seconds at 1800 VAC/ 50-60 Hz. Thermal Shock: Test per MIL-STD-202F, method 107G, condition D. Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Termination: See Mechanical Drawing. Lead wire connection suit with 22AWG 1007# Wire length=310±25.4mm Agency Approvals: UL, CUL,CE PQ Curve:
19028268A 价格&库存
很抱歉,暂时无法提供与“19028268A”相匹配的价格&库存,您可以联系我们找货
