19028423A
19028423A
    COMAIRROTRON
    插件
    19028423A
19028423A 数据手册
SPECIFICATIONS RoHS Model Number:MX3B3 Part Number: 19028423A Version: 02 Dec 18, 2017 Mechanical Drawing: Motor: Additional Features: Normal Voltage = 230 VAC Operating Voltage Range = 207~253VAC Operating Frequency = 50/60Hz Rated Current = 0.17/0.14A Input Power = 23/20Watt Average Speed = 2500/2850RPM Bearings = Ball Airflow = 90/100CFM (Measuring at zero static pressure) Static Pressure =0.20”/” 0.25’’ H2O (Measuring at zero air flow) Noise Level = 50/52 dB(A) Net Weight = 460 gram. Insulation Resistance: 100MΩ or more at 500 V megger. Dielectric strength: 2 seconds at 1800 VAC/ 50-60 Hz. Thermal Shock: Test per MIL-STD-202F, method 107G, condition D. Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Construction: Venturi: High quality magnesium alloy die-casting Frame with ED coating and powder coating, Black. Propeller: Plastic, Black, UL 94V-0. Life Expectancy: This fan is designed for continuous duty life of 55,000 hours at 70ºC. Termination: 0.120” Wide Terminals Agency Approvals: UL, CUL, CE PQ Curve:
19028423A
1. 物料型号:19028423A 2. 器件简介:COMAIR ROTRON电动机,包括机械图纸和附加特性。 3. 引脚分配:未明确列出,但提到了M4B和8-M5,可能是固定孔或安装点的规格。 4. 参数特性: - 额定电压:230 VAC,工作电压范围207至253 VAC - 频率:50/60Hz - 额定电流:0.17/0.14A - 输入功率:23/20Watt - 平均速度:2500/2850RPM - 绝缘电阻:100MΩ或更高,500V兆欧表测试 - 耐电强度:1800 VAC/ 50-60 Hz下2秒 - 热冲击:按MIL-STD-202F, 方法107G, 条件D测试 - 工作温度:-10°C至70°C - 存储温度:-40°C至85°C 5. 功能详解:包括电机的额定电流、输入功率、平均速度、轴承、风量、终止类型(0.120英寸宽的端子)和静态压力。 6. 应用信息:提供了电机的构造、文氏管、框架、螺旋桨材料和颜色,以及预期寿命(设计用于在70°C下连续工作55,000小时)。 7. 封装信息:包括UL、CUL、CE认证,噪音水平(50/52 dB(A)),净重(460克)。
19028423A 价格&库存
很抱歉,暂时无法提供与“19028423A”相匹配的价格&库存,您可以联系我们找货
