19028422A
19028422A
    COMAIRROTRON
    插件
    19028422A
19028422A 数据手册
SPECIFICATIONS RoHS Model Number:MX2B3 Part Number: 19028422A Version: 04 Dec 18, 2017 Mechanical Drawing: Motor: Additional Features: Normal Voltage = 115VAC Operating Voltage Range = 103~126VAC Operating Frequency = 50/60Hz Rated Current = 0.30/0.26A Input Power = 23/20Watt Average Speed = 2500/2850RPM Bearings = Ball Airflow = 90/100CFM (Measuring at zero static pressure) Static Pressure = 0.20/0.25’’ H2O (Measuring at zero air flow) Noise Level = 50/52 dB(A) Net Weight = 460 gram. Insulation Resistance: 100MΩ or more at 500 V megger. Dielectric strength: 2 seconds at 1800 VAC/ 50-60 Hz. Thermal Shock: Test per MIL-STD-202F, method 107G, condition D. Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Construction: This fan is designed for continuous duty life of 55,000 hours at 70ºC. Venturi: High quality magnesium alloy die-casting Frame with ED coating and powder coating, Black. Propeller: Plastic, Black, UL 94V-0. Termination: 0.120” Wide Terminals Agency Approvals: UL, CUL, CE Life Expectancy: PQ Curve :
19028422A 价格&库存
很抱歉,暂时无法提供与“19028422A”相匹配的价格&库存,您可以联系我们找货
