19028309A
19028309A
    COMAIRROTRON
    插件
    19028309A
19028309A 数据手册
SPECIFICATIONS (RoHS Compliant) Model Number: Part Number: MR77B3 19028309A Version: 01 Jan 09, 2018 Mechanical Drawing: Motor: Nominal Voltage Frequency Nominal Running Current Max. Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic Additional Features: = 220 / 230 VAC = 50 / 60 Hz = 0.13 / 0.14 Amps = 0.25 Amps = 26 / 30 Watts = 2850 / 3350 RPM = Ball = 200 / 235 CFM = 52.2 / 55.8 dBA Construction: Venturi: Single Piece Die-Cast Aluminum, Black. Propeller: Plastic, Black, UL 94V-0 Life Expectancy: This fan is designed for continuous duty life of 62,000 hours at 40C. Permanent Split Capacitor Motor Thermal Protection Automatic Restart Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Termination: 2x0.120” Terminals Agency Approvals: UL, CUL, CE PQ Curve:
19028309A 价格&库存
很抱歉,暂时无法提供与“19028309A”相匹配的价格&库存,您可以联系我们找货
