19031842A
19031842A
    COMAIRROTRON
    插件
    19031842A
19031842A 数据手册
SPECIFICATIONS Model Number: Part Number: MA2B3 19031842A Version:01 Jan 08, 2018 Mechanical Drawing: Motor: Nominal Voltage Frequency Nominal Running Current Max. Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic Additional Features: = 115 VAC = 50 / 60 Hz = 0.33 / 0.36 Amps = 0.750 Amps = 40.5 / 41.4 Watts = 2850 / 3400 RPM = Ball = 250 / 300 CFM = 54.8/ 56.5 dBA Construction: Venturi: Single piece Die-Cast Aluminum, Black Propeller: Polycarbonate, Black, UL 94V-0. Life Expectancy: This fan is designed for continuous duty life of 55,000 hours at 40C. Permanent Split Capacitor Motor Automatic Reset Thermal Protector Feathered Edge Propeller Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Termination: 2x0.11” Terminals Agency Approvals: UL, CUL, CE PQ Curve:
19031842A 价格&库存
很抱歉,暂时无法提供与“19031842A”相匹配的价格&库存,您可以联系我们找货
