19020190A
19020190A
    COMAIRROTRON
    插件
    19020190A
19020190A 数据手册
SPECIFICATIONS (RoHS Compliant) Model Number: Part Number: CLE3L2 19020190A Version: 02 Aug 07, 2018 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Frequency Nominal Running Current Max. Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic: = 230 VAC = 50/60 Hz = 0.24 / 0.25 amps = 0.355 amps = 60/60 watts = 1400/1650 RPM = Ball = 455/550 CFM = 45.4/49.2 dBA Construction: Venturi: Aluminum, Black Propeller: Plastic, Black, UL 94V-0 Life Expectancy: This fan is designed for continuous duty life of 46,000 hours at 70C. Permanent Split Capacitor Automatic Restart Thermal Protector Class B Insulation Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Termination: 24” Lead wires, 18 AWG, UL 1015 Agency Approvals: UL, CUL ,CE PQ Curve:
19020190A 价格&库存
很抱歉,暂时无法提供与“19020190A”相匹配的价格&库存,您可以联系我们找货
