19020189A
19020189A
    COMAIRROTRON
    插件
    19020189A
19020189A 数据手册
SPECIFICATIONS (RoHS Compliant) Model Number: Part Number: CLE2T2 19020189A Version:03 Aug 26, 2019 Mechanical Drawing: Motor: Nominal Voltage Frequency Nominal Running Current Max. Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic: = 115 VAC = 50 / 60 Hz =0.48 / 0.50 amps = 1.00 amps = 67 / 61 Watts = 1400 / 1650 RPM = Ball = 455 / 550 CFM = 45.4 / 49.2 dBA Additional Features: Permanent Split Capacitor Motor Automatic Reset Thermal Protector Class A Insulation Feathered Edge Propeller Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Termination: 2x0.11” Terminals Construction: Agency Approvals: Venturi: Aluminum, Black Propeller: Plastic, Black, UL 94V-0 UL, CUL,CE Life Expectancy: This fan is designed for continuous duty life of 46,000 hours at 70C. PQ Curve:
19020189A 价格&库存
很抱歉,暂时无法提供与“19020189A”相匹配的价格&库存,您可以联系我们找货
