19020172A
19020172A
    COMAIRROTRON
    插件
    19020172A
19020172A 数据手册
SPECIFICATIONS Model Number: Part Number: TNE3A 19020172A (RoHS Compliant) Version: 01 Jan 09, 2018 Mechanical Drawing: Motor: Nominal Voltage Frequency Nominal Running Current Max. Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic Additional Features: = 220/230 VAC = 50 / 60 Hz = 0.22 / 0.25 Amps = 0.60 / 0.65 Amps = 52 / 59 Watts = 2820 / 3350 RPM = Ball = 280 / 340 CFM = 61.6 / 65.4 dBA Construction: Venturi: Plastic, Black, UL 94V-0 Propeller & Cover: Plastic, Black, UL 94V-0 Life Expectancy: This fan is designed for continuous duty life of 45,000 hours at 60C. Permanent Split Capacitor Automatic Reset Thermal Protector Thermal Shutdown Protection Class B Insulation Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Termination: 2x0.12” Terminals Agency Approvals: UL, CUL, CE PQ Curve:
19020172A 价格&库存
很抱歉,暂时无法提供与“19020172A”相匹配的价格&库存,您可以联系我们找货
