19028312A
19028312A
    COMAIRROTRON
    插件
    19028312A
19028312A 数据手册
SPECIFICATIONS Model Number: Part Number: PT77B3 19028312A (RoHS Compliant) Version: 01 Jan 23, 2016 Mechanical Drawing: Motor: Nominal Voltage Frequency Nominal Running Current Max. Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic Additional Features: = 220 / 230 VAC = 50 / 60 Hz = 0.130 / 0.140 amps = 0.25 amps = 26 / 30 watts = 2880 / 3350 RPM = Ball = 200 / 235 CFM = 50.3 / 54.0 dBA Construction: Venturi: Single Piece Die-Cast Aluminum, Black Propeller: Plastic, Black, UL 94V-0 Life Expectancy: This fan is designed for continuous duty life of 62,000 hours at 40C. Permanent Split Capacitor Motor Half Speed Impedance Protection Full Speed Automatic Reset Thermal Protector Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Termination: 2x0.120” Terminals Agency Approvals: UL , CUL, CE PQ Curve:
19028312A 价格&库存
很抱歉,暂时无法提供与“19028312A”相匹配的价格&库存,您可以联系我们找货
