L138-DG-225-RI
L138-DG-225-RI
    CRITICALLINK
    L138-DG-225-RI
L138-DG-225-RI 数据手册
Critical Link, LLC www.CriticalLink.com MityDSP-L138F System on Module 3-AUG-2022 FEATURES • TI OMAP-L138 Dual Core Application Processor - 456 MHz (Max) C674x VLIW DSP ▪ Floating Point DSP ▪ 32 KB L1 Program Cache ▪ 32 KB L1 Data Cache ▪ 256 KB L2 cache ▪ 1024 KB boot ROM ▪ JTAG Emulation/Debug (option) - 456 MHz (Max) ARM926EJ-S MPU ▪ 16 KB L1 Program Cache ▪ 16 KB L1 Data Cache ▪ 8 KB Internal RAM ▪ 64 KB boot ROM ▪ JTAG Emulation/Debug (option) • On-Board Xilinx Spartan-6 FPGA - Up To XC6SLX45 ▪ Up To 2,088 KBits Block RAM ▪ Up To 6,822 Slices (6 Input LUTs) - 1050 Mbps data rate - JTAG Interface/Debug (option) • • • • • Up To 256 MB mDDR2 CPU RAM Up To 512 MB Parallel NAND FLASH Up to 16 MB SPI based NOR FLASH Integrated Power Management Standard SO-DIMM-200 Interface - 96 FPGA User I/O Pins - 10/100 EMAC MII / MDIO - 2 UARTS - 2 McBSPs - 2 USB Ports - Video Output - Camera/Video Input - MMC/SD - SATA Support (option) - Single 3.3V Power Supply (actual size) APPLICATIONS • Embedded Instrumentation • Industrial Automation • Industrial Instrumentation • Medical Instrumentation • Embedded Control Processing • Network Enabled Data Acquisition • Test and Measurement • Software Defined Radio • Bar Code Scanners • Power Protection Systems • Portable Data Terminals BENEFITS • Rapid Development / Deployment • Multiple Connectivity and Interface Options • Rich User Interfaces • High System Integration • Fixed & Floating Point Operations in Single CPU • High Level OS Support - Linux - QNX 6.4 - Windows Embedded CE Ready - ThreadX Real Time OS • Embedded Digital Signal Processing DESCRIPTION The MityDSP-L138F is a highly configurable, very small form-factor processor card that features a Texas Instruments OMAP-L138 456 MHz (max) Applications Processor (OMAP) tightly integrated with the Xilinx Spartan-6 Field Programmable Gate Array (FPGA), FLASH (NAND, and NOR) and mDDR2 RAM memory subsystems. The design of the MityDSP-L138F allows end users the capability to develop programs/logic images for both the OMAP and the FGPA. The MityDSP-L138F provides a complete and flexible digital processing infrastructure necessary for the most demanding embedded applications development. 1 Copyright © 2022, Critical Link LLC Specifications Subject to Change 60-000037-1C Critical Link, LLC www.CriticalLink.com MityDSP-L138F System on Module 3-AUG-2022 The onboard OMAP-L138 processor provides a dual CPU core topology. The OMAPL138 includes an ARM926EJ-S micro-processor unit (MPU) capable of running the rich software applications programmer interfaces (APIs) expected by modern system designers. The ARM architecture supports several operating systems, including Linux and Windows Embedded CE. In addition to the ARM core, the OMAP-L138 also includes a TMS320C674x floating point digital signal processing (DSP) core. The DSP core supports the freely provided TI DSP/BIOS real-time kernel. Users can leverage the DSP to execute real-time compute algorithms (codecs, image/data processing, compression techniques, filtering, etc.). Up to 16MB NOR Flash (SPI interface) For uBoot bootloader Up to 512MB NAND Flash 16-bit wide For root FFS 1.2V 1.8V 2.5V Power Management 3.3V EMIFA (16-bit) System Clocks JTAG/Emulator JTAG MMCSD 1 uPP LCD (Many pins are multiplexed between peripherals) Xilinx Spartan-6 FPGA XC6SLX16 CSG324 pkg. VPIF I/O Programmable I/O I/O Bank Power Boot Config Resets & RTC SATA USB 0,1 Timers eCAP eHRPWM I2C 0,1 McASP SPI 0,1 McBSP 0,1 MMCSD 0 UART 0,1,2 EMAC MII/MDIO Boot Config FPGA I/O Banks can be 1.8V, 2.5V, or 3.3V GND UHPI 3.3 V EMAC RMII Programmable I/O Texas Instruments OMAP-L138 450-MHz ARM926EJ-S ™ RISC MPU 450-MHz C674x VLIW DSP Optional JTAG Header I/O Bank Power Up to 256MB mDDR Memory 16-bit wide SO-DIMM-200 (DDR2 Connector) Figure 1 MityDSP-L138F Block Diagram Figure 1 provides a top level block diagram of the MityDSP-L138F processor card. As shown in the figure, the primary interface to the MityDSP-L138F is through a standard SO-DIMM-200 card edge interface. The interface provides power, synchronous serial connectivity, and up to 96 pins of configurable FPGA I/O for application defined interfacing. Details of the SO-DIMM-200 connector interface are included in the SODIMM-200 Interface Description, as shown below. 2 Copyright © 2022, Critical Link LLC Specifications Subject to Change 60-000037-1C Critical Link, LLC www.CriticalLink.com MityDSP-L138F System on Module 3-AUG-2022 FPGA Bank I/O The MityDSP-L138F provides 96 lines of FPGA I/O directly to the SO-DIMM-200 card edge interface. The 96 lines of FPGA I/O are distributed across 2 banks of the FPGA. These I/O lines and their associated logic are completely configurable within the FPGA at the end user’s discretion. With the Xilinx Spartan-6 series FPGA, up to the XC6SLX45, each of the user controlled banks may be configured to operate on a different electrical interface standard based on input voltage provided at the card edge connector. The banks support 3.3V, 2.5V, and 1.8V standard CMOS switching level technology. In addition, the I/O lines from the FPGA have been routed as differential pairs and support higher speed LVDS standards as well as SSTL 2.5 switching standards. Various forms of termination (pull-up/pull-down, digitally controlled impedance matching) are available within the FPGA switch fabric. Refer to the Xilinx Spartan 6 user’s guide for more information. OMAP-L138 mDDR2 Memory Interface The OMAP-L138 includes a dedicated DDR2 SDRAM memory interface shared between the onboard ARM and DSP cores. The MityDSP-L138F includes up to 256 MB of mDDR2 RAM integrated with the OMAP-L138 processor. The bus interface is capable of burst transfer rates of 600 MB / second. Note that the OSCIN frequency to the OMAPL138 processor on the module is 24MHz. OMAP-L138 SPI NOR FLASH Interface The MityDSP-L138F includes up to 16 MB of SPI NOR FLASH. This FLASH memory is intended to store a factory provided bootloader, and typically a compressed image of a Linux kernel for the ARM core processor. EMIFA - FPGA / NAND FLASH Interface The OMAP-L138 and the Spartan-6 FPGA are connected using the DSP Asynchronous External Memory Interface (EMIFA). The EMIFA interface includes 3 chip select spaces. The EMIF interface supports multiple data width transfers and bus wait state configurations based on chip select space. 8, and 16 bit data word sizes may be used. Two of the three chip select lines (CE2, CE3) are reserved for the FPGA interface. The MityDSP-L138F also includes 4 lines between the FPGA and the OMAP for the purposes of generating interrupt signals. In addition to the FPGA, up to 512 MB of on-board NAND FLASH memory is connected to the OMAP-L138 using the EMIFA bus. The FLASH memory is 8 bits wide and is connected to third chip select line of the EMIFA (CE1). The FLASH memory is typically used to store the following types of data: - ARM Linux / Windows Embedded CE / QNX embedded root file-system FPGA application images runtime DSP or ARM software runtime application data (non-volatile storage) 3 Copyright © 2022, Critical Link LLC Specifications Subject to Change 60-000037-1C Critical Link, LLC www.CriticalLink.com MityDSP-L138F System on Module 3-AUG-2022 OMAP-L138 Camera and Video Interfaces The OMAP-L138 includes an optional video port I/O interface commonly used to drive LCD screens as well as a camera input interface. These interfaces have been routed to the FPGA, which may be routed to the FPGA output pins on the SO-DIMM-200 connector. By routing the video data through the FPGA, additional user customization and/or processing (e.g., overlays of video output, preprocessing or filtering of camera input) may be offloaded from the OMAP-L138 to the FPGA for computation intensive applications. OMAP-L138 RTC The OMAP-L138 features an integrated real-time clock, RTC. MityDSP-L138F modules have a 32.768KHz tuning fork crystal connected to RTC XI & RTC XO of the OMAPL138 to support the RTC functionality. Additionally there is a battery input, module Pin 35, which will power the RTC when the module is off, if utilized. Please visit our Redmine Wiki pages at support.criticallink.com for additional details about the RTC feature. Debug Interface Both the JTAG interface signals for the FPGA and the JTAG and emulator signals for the OMAP-L138 processor have been brought out to a Hirose header that is intended for use with an available breakout adapter, Critical Link part number 80-000286. This header is not installed on standard models. To order a module with the Hirose header installed, an option code must be provided with the order. Please contact Critical Link at info@criticallink.com for details. The breakout adapter, 80-000286, is not included with individual modules but is included with each Critical Link Development Kit that is ordered. Additional adapters are available through Critical Link distribution partners. Software and Application Development Support Users of the MityDSP-L138F are encouraged to develop applications and FPGA firmware using the hardware and software development kit provided by Critical Link. The development kit includes a board support package providing a Linux based distribution and compatible gcc compiler tool-chain with debugger. In addition, the development kit includes support libraries necessary to program the DSP core using the TI Code Composer Studio DSP compiler tool-chain. To support rapid FPGA and applications development, netlist components - compatible with the Xilinx ISE FPGA synthesis tool – for commonly used FPGA designs and a corresponding set of Linux loadable kernel modules and/or DSP interface APIs are included. The libraries provide the necessary functions needed to configure the MityDSP-L138F, program standalone embedded applications, and interface with the various hardware components both on the processor board as well as a custom application carrier card. The libraries include several interface “cores” – FPGA and DSP software modules designed to interface with various high performance data converter 4 Copyright © 2022, Critical Link LLC Specifications Subject to Change 60-000037-1C Critical Link, LLC www.CriticalLink.com MityDSP-L138F System on Module 3-AUG-2022 modules (ADCs, DACs, LCD and touchscreen interfaces, etc) – as well as bootloading and FLASH programming utilities. Growth Options The MityDSP-L138F has been designed to support several upgrade options. These options include various speed grades, memory configurations, and operating temperature specifications including commercial and industrial temperature ranges. The available options are listed in the section below containing ordering information. For additional ordering information and details regarding these options, or to inquire about a particular configuration not listed below, please contact Critical Link at info@criticallink.com. ABSOLUTE MAXIMUM RATINGS Maximum Supply Voltage, Vcc Storage Temperature Range Shock, Z-Axis Shock, X/Y-Axis OPERATING CONDITIONS 3.5 V o 0oC to 70oC Ambient Temperature Range Commercial Ambient Temperature Range Industrial Humidity o -65 C to 80 C ±10 g ±10 g -40oC to 85oC 0 to 95% Non-condensing Contact Critical Link for Details MIL-STD-810F SO-DIMM-200 Interface Description The primary interface connector for the MityDSP-L138F is the SO-DIMM card edge interface which contains 4 types of signals: • • • • Power (PWR) Dedicated signals mapped to the OMAP-L138 device (D) Multi-function signals mapped to the OMAP-L138 device (M) Dedicated signals mapped to the Xilinx Spartan 6 device (F) Table 1 contains a summary of the MityDSP-L138F pin mapping. Pin 1 3 5 7 9 11 135 155 175 Ball K14 J1 J2 L1 Type PWR PWR PWR PWR PWR D D D D I/O I O O I Table 1 SO-DIMM Pin-Out Signal Pin Ball Type +3.3 V in 2 PWR +3.3 V in 4 PWR +3.3 V in 6 PWR GND 8 PWR GND 10 PWR RESET_IN# 12 D SATA_TX_P 14 A4 M SATA_TX_N 16 A3 M SATA_RX_P 18 A2 M 5 I/O I/O I/O I/O Signal +3.3 V in +3.3 V in +3.3 V in GND GND EXT_BOOT# GP0_7 GP0_10 GP0_11 Copyright © 2022, Critical Link LLC Specifications Subject to Change 60-000037-1C Critical Link, LLC www.CriticalLink.com Pin 195 21 23 25 27 29 31 33 35 37 39 41 43 45 47 491 51 53 552 572 59 Ball L2 P16 P18 P19 N19 M18 M19 K18 H17 G17 H16 G19 F18 G16 G18 F16 Type D D D D D D D D D PWR PWR PWR D D D D M D D D M I/O I I I/O I/O O I/O I/O O I/O I/O I/O I/O I/O I/O I/O I/O I/O 61 F17 M I/O 63 65 67 69 71 73 75 77 79 81 83 85 87 89 91 93 95 97 99 101 103 105 107 109 111 113 115 F19 E18 E16 D17 D19 C17 D16 E17 D18 C19 C18 C16 U17 U18 T17 T18 P17 P18 N17 N18 M16 M18 L17 L18 PWR M M M M M M M M M M PWR M M F F F F F F F F PWR F F F F I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O Signal SATA_RX_N USB0_ID USB1_D_N USB1_D_P USB0_VBUS USB0_D_N USB0_D_P USB0_DRVVBUS 3V RTC Battery +3.3 V in +3.3 V in GND SPI1_MISO SPI1_MOSI SPI1_ENA SPI1_CLK SPI1_SCS1 Reserved I2C0_SCL I2C0_SDA UART2_TXD I2C1_SDA UART2_RXD I2C1_SCL GND UART1_TXD UART1_RXD MDIO_CLK MDIO_DAT MII_RXCLK MII_RXDV MII_RXD0 MII_RXD1 MII_RXD2 MII_RXD3 GND MII_CRS MII_RXER B1 _47_P.U17 B1_ 47_N.U18 B1 _45_P.T17 B1_ 45_N.T18 B1_43_P.P17 B1_43_N.P18 B1_41_P.N17 B1_41_N.N18 GND B1_39_P.M16 B1_39_N.M18 B1_37_P.L17 B1_37_N.L18 MityDSP-L138F System on Module 3-AUG-2022 / Pin 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 Ball A1 B4 B1 B2 B3 C2 C3 C4 C5 D4 E4 F4 D5 A12 C11 E12 B11 E11 Type M M M M M M M M M PWR PWR PWR M M M M M M M M M I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O Signal GP0_15 GP0_6 GP0_14 GP0_12 GP0_5 GP0_13 GP0_1 GP0_4 GP0_3 +3.3 V in +3.3 V in GND GP0_2 GP0_0 GP0_8 GP0_9 MMCSD0_DAT7 MMCSD0_DAT6 MMCSD0_DAT5 MMCSD0_DAT4 MMCSD0_DAT3 / 62 C10 M I/O MMCSD0_DAT2 64 66 68 70 72 74 76 78 80 82 84 86 88 904 92 94 96 98 100 102 104 106 108 110 112 114 116 A11 B10 A10 E9 D3 E3 E2 E1 F3 C1 D1 R16 M14 N14 N15 N16 L12 L13 K12 K13 L15 L16 K15 K16 PWR M M M M M M M M M M PWR M F F F F F F F F F PWR F F F F I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O GND MMCSD0_DAT1 MMCSD0_DAT0 MMCSD0_CMD MMCSD0_CLK MII_TXCLK MII_TXD3 MII_TXD2 MII_TXD1 MII_TXD0 MII_TXEN GND MII_COL FPGA_SUSPEND B1 _48_P.M14 B1_ 48_N.N14 B1 _46_P.N15 B1_ 46_N.N16 B1 _44_P.L12 B1_ 44_N.L13 B1 _42_P.K12 B1_ 42_N.K13 GND B1 _40_P.L15 B1_ 40_N.L16 B1 _38_P.K15 B1_ 38_N.K16 6 Copyright © 2022, Critical Link LLC Specifications Subject to Change 60-000037-1C Critical Link, LLC www.CriticalLink.com Pin 117 119 121 123 125 127 129 131 133 135 137 139 141 143 145 147 149 151 153 155 157 159 161 163 165 167 169 171 173 175 177 179 181 183 185 187 189 191 193 195 197 199 Ball K17 K18 J16 J18 H17 H18 G16 G18 F17 F18 E16 E18 D17 D18 C17 C18 B16 A16 C15 A15 B14 A14 C13 A13 B12 A12 B11 A11 C10 A10 B9 A9 B8 A8 C7 A7 - Type F F F F F F PWR F F F F F F F F F F PWR F F F F F F F F F F PWR F F F F F F F F F F PWR PWR PWR I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O - Signal B1_35_P.K17 B1_35_N.K18 B1_33_P.J16 B1_33_N.J18 B1_31_P.H17 B1_31_N.H18 GND B1_29_P.G16 B1_29_N.G18 B1_27_P.F17 B1_27_N.F18 B1_25_P.E16 B1_25_N.E18 B1_23_P.D17 B1_23_N.D18 B1_21_P.C17 B1_21_N.C18 GND B0_19_P.B16 B0_19_N.A16 B0_17_P.C15 B0_17_N.A15 B0_15_P.B14 B0_15_N.A14 B0_13_P.C13 B0_13_N.A13 B0_11_P.B12 B0_11_N.A12 GND B0_9_P.B11 B0_9_N.A11 B0_7_P.C10 B0_7_N.A10 B0_5_P.B9 B0_5_N.A9 B0_3_P.B8 B0_3_N.A8 B0_1_P.C7 B0_1_N.A7 GND VCCO_1 VCCO_1 MityDSP-L138F System on Module 3-AUG-2022 Pin 118 120 122 124 126 128 130 132 134 136 138 140 142 144 146 148 150 152 1543 1563 1583 1603 1623 1643 166 168 1703 1723 174 176 178 180 182 184 186 188 190 192 194 196 198 200 Ball J13 K14 H15 H16 H13 H14 F15 F16 H12 G13 F14 G14 F13 E13 D14 C14 F12 E12 D12 C12 F11 E11 D11 C11 E7 E8 D9 C9 D8 C8 D6 C6 B6 A C5 A5 - Type F F F F F F PWR F F F F F F F F F F PWR F F F F F F F F F F PWR F F F F F F F F F F PWR PWR PWR I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O3 I/O3 I/O3 I/O3 I/O3 I/O3 I/O I/O I/O3 I/O3 I/O I/O I/O I/O I/O I/O I/O I/O I/O I/O - Signal B1 _36_P.J13 B1_ 36_N.K14 B1 _34_P.H15 B1_ 34_N.H16 B1 _32_P.H13 B1_ 32_N.H14 GND B1 _30_P.F15 B1_ 30_N.F16 B1 _28_P.H12 B1_ 28_N.G13 B1 _26_P.F14 B1_ 26_N.G14 B0 _24_P.F13 B0_ 24_N.E13 B0 _22_P.D14 B0_ 22_N.C14 GND B0 _20_P.F123 B0_ 20_N.E123 B0 _18_P.D123 B0_ 18_N.C123 B0 _16_P.F113 B0_ 16_N.E113 B0 _14_P.D11 B0_ 14_N.C11 B0 _12_P.E73 B0_ 12_N.E83 GND B0 _10_P.D9 B0_ 10_N.C9 B0 _8_P.D8 B0_ 8_N.C8 B0 _6_P.D6 B0_ 6_N.C6 B0 _4_P.B6 B0_ 4_N.A6 B0 _2_P.C5 B0_ 2_N.A5 GND VCCO_0 VCCO_0 Note 1: Pin 49, SPI1_CLK, has a 100K Ohm pull-down resistor on the module Note 2: Pins 55 and 57 have 4.70K pull-up resistors on the module Note 3: The Xilinx 6SLX45 FPGA does not bond I/O Buffers to balls E7, E8, F11, E11, D12, C12, E12, and F12 of the package used for this module. For MityDSP-L138F configurations using this FPGA option, these edge connector signals should be treated as no-connects and will not function as FPGA I/O lines. Note 4: Pin 90, FPGA_SUSPEND, has a 4.7K Ohm pull-down resistor on the module 7 Copyright © 2022, Critical Link LLC Specifications Subject to Change 60-000037-1C Critical Link, LLC www.CriticalLink.com MityDSP-L138F System on Module 3-AUG-2022 Note 5: The SATA peripheral interface is only supported on modules ordered with the SATA option code. Contact Critical Link for details. The signal group description for the above pins is included in Table 2. 8 Copyright © 2022, Critical Link LLC Specifications Subject to Change 60-000037-1C Critical Link, LLC www.CriticalLink.com MityDSP-L138F System on Module 3-AUG-2022 Table 2 Signal Group Description Signal / Group 3.3 V in EXT_BOOT# I/O N/A I RESET_IN# I SPI_XXXX I/O MII_XXXX I/O MDIO_XX I/O GP0_X IO SATA_TX_P/N O SATA_RX P/N I GND BX_Y_P.ZZ, BX_Y_N.ZZ N/A IO Description 3.3 volt input power referenced to GND. Bootstrap configuration pin. Pull low to configure booting from external UART1. Manual Reset. When pulled to GND for a minimum of 1 usec, resets the DSP processor. The pins with an SPI_ prefix are direct connections to the OMAP-L138 pins supporting the SPI1 interface. The SPI1_CLK, SPI1_ENA, SPI1_MISO, SPI1_MOSI pins must remain configured for the SPI function in order to support interfacing to the onboard SPI boot ROM. For details please refer to the OMAP-L138 processor specifications. The pins with an MII_ prefix are direct connections to the OMAP-L138 pins supporting the media independent interface (MII) function. The MII pins provide multiplex capability and may alternately be used as UART, GPIO, and SPI control pins. For details please refer to the OMAP-L138 processor specification. The MDIO_CLK and MDIO_DAT signals are direct connects to the corresponding MDIO signals on the OMAP-L138 processor. These pins may be configured for GPIO. General Purpose / multiplexed pins. These pins are direct connects to the corresponding GP0[X] pins on the OMAP-L138 processor. The include support for the McASP, general purpose I/O, UART flow control, and McBSP 1. For details please refer to the OMAP-L138 processor specifications. These pins are direct connects to the OMAP-L138 SATA_TX differential Serial ATA controller pins. The SATA peripheral interface is only supported on devices ordered with the SATA option code. For details contact Critical Link. These pins are direct connects to the OMAP-L138 SATA_RX differential Serial ATA controller pins. The SATA peripheral interface is only supported on devices ordered with the SATA option code. For details contact Critical Link. System Digital Ground. FPGA I/O pins. These pins are routed directly to FPGA pins ZZ. The “X” indicates which FPGA bank the pin is allocated. The bank is either 0 or 1. 9 Copyright © 2022, Critical Link LLC Specifications Subject to Change 60-000037-1C Critical Link, LLC www.CriticalLink.com Signal / Group MityDSP-L138F System on Module 3-AUG-2022 I/O VCCO_X I USB0_XXXX, USB1_XXXX I/O Description The FPGA fabric supports routing pins in differential pairs, the Y_P and Y_N portion of the name indicates the pair number and polarity. The pins have been routed in pairs with phase matched line lengths. FPGA Bank interface power input. These pins must be tied to the desired voltage used for the FPGA Bank 0 or 1 interface pins. Please refer to the VCCO input pin specifications for the Xilinx Spartan 6 family of devices for further information. Typical values are 3.3V and 2.5 volts. Each VCCO_X pair should have a 100uF X5R (or better) capacitor place near the pins on the carrier board. The USBN_ prefixed pins are direct connects to the corresponding pins on the OMAP-L138 processor. For details please refer to the OMAP-L138 processor specifications. DEBUG INTERFACE Below is the pin-out for the Hirose 31 pin header (DF9-31P-1V(32)) that interfaces with an available adapter board, Critical Link part number 80-000286, to debug the OMAPL138 and FPGA. The debug interface connector is only installed on devices ordered with the JTAG option code. For details contact Critical Link. Debug Interface Connector Description (J2) Pin 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 I/O - GND GND GND GND GND GND GND GND GND GND GND GND GND GND GND GND Table 3 OMAP-L138 Hirose Connector Signal Pin I/O Signal 2 O OMAP EMU1 4 O OMAP EMU0 6 I OMAP TCK 8 O OMAP RTCK 10 O OMAP TDO 12 OMAP VCC / 3.3V 14 I OMAP TDI 16 I OMAP TRST 18 I OMAP TMS 20 GND 22 O FPGA VREF / VCCAUX 24 I FPGA TMS 26 I FPGA TCK 28 O FPGA TDO 30 I FPGA TDI 10 Copyright © 2022, Critical Link LLC Specifications Subject to Change 60-000037-1C Critical Link, LLC www.CriticalLink.com MityDSP-L138F System on Module 3-AUG-2022 11 Copyright © 2022, Critical Link LLC Specifications Subject to Change 60-000037-1C Critical Link, LLC www.CriticalLink.com MityDSP-L138F System on Module 3-AUG-2022 ELECTRICAL CHARACTERISTICS Table 4: Electrical Characteristics Parameter Conditions Min Symbol V33 I33 I33-max V3V_RTC_Battery I3V_RTC_Battery FCPU FEMIF Voltage supply, 3.3 volt input. Quiescent Current draw, 3.3 volt input Max current draw, positive 3.3 volt input. Voltage supply, RTC Battery Current, RTC Battery, V33 = 0V CPU internal clock Frequency (PLL output) EMIF bus frequency 1. 2. 3.2 Must be ½ CPU 25 - Typ Max Units 3.3 3401,2 TBS1,2 3.0 10 300 100 3.4 TBS1,2 22001,2 5.0V Volts mA mA Volts uA MHz MHz 456 - Power utilization of the MityDSP-L138F is heavily dependent on end-user application. Major factors include: ARM CPU PLL configuration, DSP Utilization FPGA utilization, and external DDR2 RAM utilization. For power utilization information please visit our Redmine Wiki pages on support.criticallink.com ORDERING INFORMATION The following table lists the standard module configurations. For shipping status, availability, and lead time of these or other configurations please contact Critical Link at info@criticallink.com. Module P/N L138-FG-325-RC L138-DG-325-RI L138-DG-325-RI-1 L138-FI-325-RC L138-DI-325-RI L138-DI-336-RI L138-FI-336-RL L138-FG-326-RC CPU 456 MHz 375 MHz 375 MHz 456 MHz 375 MHz 375 MHz 456 MHz 456 MHz Table 5: Standard Model Numbers* FPGA NOR NAND 6SLX16 16MB 256MB 6SLX16 16MB 256MB 6SLX16 16MB 256MB 6SLX45 16MB 256MB 6SLX45 16MB 256MB 6SLX45 16MB 512MB 6SLX45 16MB 512MB 6SLX16 16MB 256MB RAM 128MB 128MB 128MB 128MB 128MB 256MB 256MB 256MB Temperature 0oC to 70o C -40oC to 85o C -40oC to 85o C 0oC to 70o C -40oC to 85o C -40oC to 85o C -40oC to 70o C 0oC to 70o C *Standard Model configurations do not include SATA support or the JTAG interface connector, J2. Contact Critical Link for orderable option codes for either or both features. 12 Copyright © 2022, Critical Link LLC Specifications Subject to Change 60-000037-1C Critical Link, LLC www.CriticalLink.com MityDSP-L138F System on Module 3-AUG-2022 MECHANICAL INTERFACE The mechanical outline of the MityDSP-L138F is illustrated in Figure 2, as shown below. Figure 2 MityDSP-L138F Mechanical Outline 13 Copyright © 2022, Critical Link LLC Specifications Subject to Change 60-000037-1C Critical Link, LLC www.CriticalLink.com MityDSP-L138F System on Module 3-AUG-2022 REVISION HISTORY Rev n/a n/a n/a Date 7-NOV-2009 10-NOV-2009 15-JAN-2010 n/a 16-MAR-2010 n/a n/a 6-APR-2010 21-APR-2010 n/a 26-JUL-2010 n/a 11-FEB-2011 n/a 02-JUN-2011 n/a 12-JUL-2011 n/a 28-NOV-2011 n/a 13-AUG-2012 n/a 11-DEC-2012 n/a 29-AUG-2013 -1A 18-JUN-2019 -1B 21-OCT-2020 -1C 3-AUG-2022 Change Description Preliminary Draft, product overview Updates after initial review. Updates to features, applications and benefits Finalize connector pin-outs. Update mechanical outlines. Update product photo and speed grade. Update specifications and options. Update ordering information, images and mechanical drawing. Correct edge connector Table 1. Update speed grade to max 456 MHz. Updated DDR rate to support 150 MHz clocking. Update model p/n table. Update edge connector Table 1 to indicate unavailable FPGA pins for 6SLX45 options. Update NAND to indicate 8 bit data width. Update block diagram accordingly. Update list of orderable part numbers. Fix typo in signal names for pins 79, 81, 83, and 84 Update Debug Header information, added MILSTD-810F and Up To notation for RAM and NAND Added OMAP-L138 processor pins and FPGA pins to Table 1 with notes about on module resistors for specific pins as well as the OSCIN frequency. Added 16MB NOR option and model numbers and RTC info. Update list of orderable part numbers and VCCO capacitor recommendation. Updated to make SATA and JTAG connector not part of standard configuration (option only). 14 Copyright © 2022, Critical Link LLC Specifications Subject to Change 60-000037-1C
L138-DG-225-RI 价格&库存
很抱歉,暂时无法提供与“L138-DG-225-RI”相匹配的价格&库存,您可以联系我们找货
