Technical Data 4303
Effective October 2015
Supersedes March 2007
CCFL Transformers
Cold cathode fluorescent lamp inverter transformers
Applications
CCFL power supplies
Environmental data
Storage temperature range: -40°C to +85°C
Operating ambient temperature range:
0°C to +70°C
Packaging
Product description
Transformers for use in CCFL power supplies,
available in through-hole and surface mount
recess or gull wing versions, incorporating
floating or fixed secondary technology
Supply output current up to 30 milli-Amps
Frequency range from 40 to 80 KHz
Deliver output power from 2.5 to 14 Watts
Operate in royer and other topologies
Ferrite core material
Supplied in bulk packaging
Pb
CCFL Transformers
Technical Data 4303
Product specifications
DCRp
ohms
max
DCRs
ohms
max
TR
Ns/Np
Vpri
volts
max2
Vsec
volts
max2
Is
max
A rms
Vpri
abnormal3
Vsec
abnormal3
Mechanical
dimensions
PCB pad
layout
43
0.220
285
67
.005
30
2000
A
A
2.5
43
0.220
285
67
.005
30
2000
A
A
2.5
26
0.190
285
86
15
1340
.005
23
2000
A
A
B
2.5
19
0.220
285
100
13
1340
.005
23
2000
A
A
A
2.5
43
0.220
285
67
.005
30
2000
B
B
CTX210655-R
B
2.5
43
0.220
285
67
.005
30
2000
B
B
CTX210657-R
B
2.5
26
0.212
285
86
15
1340
.005
23
2000
B
B
CTX210659-R
B
2.5
19
0.190
285
100
13
1340
.005
23
2000
B
B
CTX210403-R
C
4
44
0.220
165
50
26
1340
.007
40
2000
C
C
CTX210407-R
C
4
27
0.160
220
86
15
1340
.007
23
2000
C
C
CTX210409-R
C
4
220
100
13
1340
.007
23
2000
C
C
CTX210411-R
C
4
330
125
10
1340
.007
16
2000
C
C
CTX310403-R
C
4
44
0.220
165
50
26
1340
.007
40
2000
D
D
CTX310407-R
C
4
27
0.160
220
86
15
1340
.007
23
2000
D
D
CTX310409-R
C
4
220
100
13
1340
.007
23
2000
D
D
CTX310411-R
C
4
330
125
10
1340
.007
16
2000
D
D
CTX110600-R
D
6
44
0.160
176
67
.011
30
2000
E
E
CTX110603-R
C
6
44
0.160
132
50
26
1340
.011
40
2000
E
E
CTX110605-R
C
6
44
0.160
176
67
.011
30
2000
E
E
CTX110607-R
C
6
27
0.132
176
86
15
1340
.011
23
2000
E
E
CTX110609-R
C
6
176
100
13
1340
.011
23
2000
E
E
CTX110611-R
C
6
291
125
11
1340
.011
16
2000
E
E
CTX210600-R
D
6
44
0.160
176
67
.011
30
2000
F
C
CTX210603-R
C
6
44
0.160
132
50
26
1340
.011
40
2000
F
C
CTX210605-R
C
6
44
0.160
176
67
.011
30
2000
F
C
CTX210607-R
C
6
27
0.132
176
86
15
1340
.011
23
2000
F
C
CTX210609-R
C
6
176
100
13
1340
.011
23
2000
F
C
CTX210611-R
C
6
291
125
11
1340
.011
16
2000
F
C
CTX410805-R
E
14
24
0.030
262
67
.030
30
2000
G
F
CTX410807-R
E
14
16
0.024
272
86
15
1340
.030
23
2000
G
F
CTX410809-R
E
14
16
0.024
314
100
13
1340
.030
23
2000
G
F
Schematic
diagram
Pout
watts
Lp uH
CTX110652-R
A
2.5
CTX110655-R
B
CTX110657-R
B
CTX110659-R
CTX210652-R
Part number
1
2.5 Watt Versions
2.5 Watt Versions
6 Watt Versions
14 Watt Versions
1. Inductances are nominal values
2. Continuous RMS Voltage
3. Maximum Instantaneous RMS Voltage
2
www.eaton.com/elx
CCFL Transformers
Technical Data 4303
Dimensions–mm
2.5 Watt Versions
Pad Layout A
Mechanical B
Mechanical A
TOP VIEW
Pad Layout B
TOP VIEW
Schematic A
Schematic B
4 Watt Versions
Mechanical C
Pad Layout C
Mechanical D
TOP VIEW
Pad Layout D
TOP VIEW
Schematic C
www.eaton.com/elx
3
CCFL Transformers
Technical Data 4303
Dimensions–mm
6 Watt Versions
Mechanical E
Mechanical F
Pad Layout E
TOP VIEW
TOP VIEW
Schematic D
Schematic C
14 Watt Versions
Schematic E
Pad Layout F
Mechanical G
BOTTOM VIEW
4
www.eaton.com/elx
Pad Layout C
CCFL Transformers
Technical Data 4303
Through-hole wave solder profile
Reflow soldering not recommended
tp
Temperature
Tp
First Wave
Second Wave
Tsmax
Tstyp
Tsmin
Preheat area
Cool down area
Time
Reference EN 61760-1:2006
Profile Feature
Standard SnPb Solder
Lead (Pb) Free Solder
• Temperature min. (Tsmin)
100°C
100°C
• Temperature typ. (Tstyp)
120°C
120°C
• Temperature max. (Tsmax)
130°C
130°C
• Time (Tsmin to Tsmax) (ts)
70 seconds
70 seconds
D preheat to max Temperature
150°C max.
150°C max.
Peak temperature (TP)*
235°C – 260°C
250°C – 260°C
Time at peak temperature (tp)
10 seconds max
5 seconds max each wave
10 seconds max
Ramp-down rate
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
Time 25°C to 25°C
4 minutes
4 minutes
Preheat
Manual solder
350°C, 4-5 seconds. (by soldering iron), generally manual, hand soldering is not recommended.
www.eaton.com/elx
5
CCFL Transformers
Technical Data 4303
Surface mount solder reflow profile
Wave and manual soldering not recommended
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“CTX210605TR-R”相匹配的价格&库存,您可以联系我们找货
