19030599A
19030599A
    COMAIRROTRON
    插件
    19030599A
19030599A 数据手册
SPECIFICATIONS Model Number: Part Number: MC24B7 19030599A (RoHS Compliant) Drawing Number: 26020940A00 Jan.01.2013 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic Additional Features: = 24 vdc = 12 - 28 vdc = 0.230 amps = 0.830 amps = 5.5 watts = 3700 = Ball = 102 cfm = 47.8 dBA Construction: Venturi: Plastic, Black, UL 94V-0 Propeller: Plastic, Black, UL 94V-0 Life Expectancy: This fan is designed for continuous duty life of 75,000 hours at 40C. Agency Approvals: UL, CE Brushless DC Motor Polarity Protected. Locked Rotor Protection Automatic Restart Operating Temperature: Storage Temperature: -10C to 70C -40C to 85C Tachometer: Output: 5 V TTL Ic: 5 mA Typical Pulses per Revolution: 2 Isolated: No Termination: 12” Lead wires, 22 AWG, UL 1061 Red = Power (+) Black = Ground (-) Blue/White = Tachometer (Output)
19030599A 价格&库存
很抱歉,暂时无法提供与“19030599A”相匹配的价格&库存,您可以联系我们找货
