SPECIFICATIONS
(RoHS Compliant)
Model Number:
Part Number:
MDD48K6S3
19039646A
Dec. 31, 2015
Mechanical Drawing:
Additional Features:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustic
= 48 vdc
= 24 – 56 vdc
= 0.160 amps
= 0.600 amps
= 7.7 watts
= 3600 rpm
= Ball
= 128 CFM
= 53.2 dBA
Brushless DC Motor
Electronic Locked Rotor Protection
Automatic Restart Capability
Polarity Protected
Operating Temperature:
-10C to 70C
Storage Temperature:
-40C to 85C
Thermal Speed Control – PTC in hub
Tachometer Output:
Output:
5 volt TTL
5 mA. Typ.
1
No
Venturi: Polypropylene, Black, UL 94V-0
Propeller: Polypropylene, Black, UL 94V-0
Ic:
Pulses per Revolution:
Isolated:
Life Expectancy:
Termination:
This fan is designed for continuous duty life of 83,000 hours
at 40C
8” Harness, Lead wires -22AWG, UL1061
Connector, Dupont 78211-003; Pins, Dupont 47565-000
Shrink Tubing around Terminal Wires
Pin 1: Red – Power
Pin 2: Blue/White – Tachometer
Pin 3: Black – Return
Construction:
Agencies:
UL, CE
很抱歉,暂时无法提供与“19039646A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+538.799481+66.83783
- 20+415.9466320+51.59799
- 40+391.6702140+48.58651
- 60+378.1105860+46.90445
- 100+361.66963100+44.86495
- 260+332.73617260+41.27577
