19031200A
19031200A
    COMAIRROTRON
    插件
    19031200A
19031200A 数据手册
SPECIFICATIONS Model Number: Part Number: GL12B7 19031200A March 19, 2004 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 12 vdc = 6 - 14 vdc = 1.30 amps = 3.00 amps = 16.0 watts = 3200 rpm = Ball = 150 CFM = 53.6 dBA Construction: Venturi: Die Cast Zinc, Black Propeller: Plastic, Black, UL 94V-0 Life Expectancy: This fan is designed for continuous duty life of 90,000 hours at 40C. Agency Approvals: UL Brushless DC Motor Locked Rotor Protection Automatic Restart Capability Polarity Protected Operating Temperature: Storage Temperature: -10C to 70C -40C to 85C Tachometer Output: Output: 5 volt TTL Compatible Ic: 5 mA Typical Pulses per Revolution: 2 Isolated: No Termination: 12” Lead wires, 22 AWG, UL 1061 Red - Fan Power (+) Black - Fan Ground (-) Blue/White - Tachometer (Output)
19031200A 价格&库存
很抱歉,暂时无法提供与“19031200A”相匹配的价格&库存,您可以联系我们找货
