Technical Data 4316
Effective July 2017
Supersedes September 2009
Power Over Ethernet (PoE)/PD
Configurable flyback transformer
Applications
For IEEE 802.3af-compliant Power-overEthernet applications
UPS, VoiP phone, Wireless LAN access point,
Bluetooth access point, Network camera,
Building access systems
Retail point-of-information systems
Vending and gaming machines
Environmental data
Product features
Versatile design allows multiple output variations
Flyback topology, 250 kHz switching frequency
Input range from 29.5 V- 60.0 V
1500 Vac isolation between primary and
secondary
Three power levels: 4, 7 and 13 watts
Low leakage inductance
11.0 V @ 0.10 A feedback winding
Ferrite core material
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Technical Data 4316
Effective July 2017
Product specifications
Inductance
Watts (µH)
4
200
4
200
4
200
Part Number
PoE4W3x3.3-R
PoE4W3x5.0-R
PoE4W2x12-R
(3)x3.3V@0.45A
(3)x5.0V@0.30A
(2)x12.0V@0.20A
DCR/
PRI
(Ω)
0.500
0.500
0.500
DCR/
SEC
(Ω)
0.07
0.27
0.740
Output
Turn Ratio
Leakage
Pri
Inductance Current Schematic 1: Pins pri(1-3):fb(5-6):v1(12-7):v2(11-8):v3(10-9)
(µH) typ. Pk (Adc)
Schematic 2: Pins pri(1-3):fb(5-6):v1(12-10):v2(11-9)
2.75
0.65
1 : 0.52 : 0.16 : 0.16 : 0.16 ±1%
2.50
0.65
1 : 0.52 : 0.26 : 0.26 : 0.26 ±1%
1.40
0.65
1 : 0.52 : 0.60 : 0.60 ±1%
Schematic
1
1
2
Dimensions
Size 1
Size 1
Size 1
PoE7W3x3.3-R
PoE7W3x5.0-R
PoE7W2x12-R
7
7
7
100
100
100
(3)x3.3V@0.75A
(3)x5.0V@0.50A
(2)x12.0V@0.30A
0.275
0.275
0.275
0.03
0.095
0.250
1.00
1.00
1.00
1.00
1.00
1.00
1 : 0.529 : 0.176 : 0.176 : 0.176 ±1%
1 : 0.529 : 0.265 : 0.265 : 0.265 ±1%
1 : 0.529 : 0.588 : 0.588 ±1%
1
1
2
Size 1
Size 1
Size 1
PoE13W3x3.3-R
PoE13W3x5.0-R
PoE13W2x12-R
13
13
13
100
100
100
(3)x3.3V@1.35A
(3)x5.0V@0.90A
(2)x12.0V@0.60A
0.250
0.250
0.250
0.032
0.075
0.280
1.50
1.20
1.00
1.60
1.60
1.70
1 : 0.529 : 0.176 : 0.176 : 0.176 ±3%
1 : 0.529 : 0.265 : 0.265 : 0.265 ±3%
1 : 0.529 : 0.647 : 0.647 ±3%
1
1
2
Size 2
Size 2
Size 2
Output
DCR/
PRI
(Ω)
DCR/
SEC (Ω)
V1/V2/V3
0.085
0.042
0.025
0.038/
0.027/na
Schematic
Dimensions
Inductance
Watts (µH)
Part Number
PoE13W3VERS-R
13
100
PoE13W2VERS-R
13
100
V1:7.0V@1.1A,
V2:(1)x3.3V@1.1A,
V3:1.8V@1.1A
V1:5.0V@1.6A,
V2:3.3V@1.6A
0.250
0.250
Turn Ratio
Leakage
Pri
Inductance Current
(µH) typ. Pk (Adc) Schematic 3: Pins pri(1-3):fb(5-6):v1(12-11):v2(10-9):v3(8-7)
1.00
1.70
1 : 0.529 : 0.350 : 0.176 : 0.088 ±3%
3
Size 2
1.20
1.70
1 : 0.529 : 0.265 : 0.176 ±3%
2
Size 2
3) Leakage Inductance 200 kHz, 0.01 Vrms, 0.0 Adc
1) Test Parameters: 100 kHz, 0.100 Vrms, 0.0 Adc
4) Feedback DCR 1.0 Ω maximum @ +20 °C
2) DCR limits maximum @ +20 °C
Dimensions- mm
A
max.
17.1
18.0
Size 1
Size 2
B
ref.
16.0
18.0
C
max.
22.3
24.6
D
ref.
0.7
0.7
E
max.
8.4
10.0
F
ref.
3.0
3.3
G
ref.
0.1
0.1
1) Tolerances A - H are ± 0.25 mm unless specified otherwise.
2) Tolerances I - O are ± 0.10 mm unless specified otherwise.
H
ref.
0.4
0.4
I
ref.
14.49
14.25
J
mm
1.79
1.75
K
mm
3.43
3.43
L
ref.
16.88
19.14
M
max.
23.74
26.0
N
O
2.54
2.5
0.75
0.75
3) All soldering surfaces are coplaner to within ± 0.102 mm.
Top View
Front View
Recommended Pad Layout
White Dot Pin #1
M
D
(12 plcs)
E
12
1
L
PoE
H
(12 plcs)
A
G
(12 plcs)
1
F
(2 plcs)
J
(12plcs)
6
B
K
(12plcs)
C
Do not route traces or vias underneath the transformer
Schematic 1
Primary
Output
Schematic 2
Primary
Output
Schematic 3
Primary
2
Feedback
Output
www.eaton.com/electronics
Output
Output
Output
Feedback
Component Side
I
7
6
12
Output
Feedback
Output
O
(10plcs)
N
(10plcs)
7
Technical Data 4316
Effective July 2017
Packaging information- mm
PoE 4 and 7 Watt
PoE 13 Watt
Parts packaged on 13" Diameter reel, 200
parts per reel.
Parts packaged on 13" Diameter reel, 140
parts per reel.
3
Technical Data 4316
Effective July 2017
Solder Reflow Profile
TP
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
25°C
Preheat
A
T smax
t
TC -5°C
Table 1 - Standard SnPb Solder (Tc)
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
ts
Package
Thickness
2.5mm
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4316 BU-SB09865
July 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“POE7W3X3.3-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 200+86.45670200+10.84602
