Technical Data 4081
Effective July 2017
Supersedes September 2009
Power Over Ethernet (PoE)/PD
Configurable forward transformer
Applications
For IEEE 802.3af-compliant Power over
Ethernet applications
UPS, VoiP phone, Wireless LAN access point,
Bluetooth access point, Network camera,
Building access systems
Retail Point-of-information systems
Vending and gaming machines
Environmental data
Product features
Versatile design allows multiple output variations
Forward topology, 300 kHz switching frequency
Input range from 29.5 V - 60.0 V
1500 Vac isolation between primary and secondary
Power 26 watts
Low leakage inductance
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Technical Data 4081
Effective July 2017
Product specifications
Primary
Induct.
Part Number
Watts
(uH)
Output
Bias
Sync
PoE26W3.3VS5-R 26
160
(2)x3.3V@4.0A 10.0V@0.1A 5V@0.1A
PoE26W3.3VS10-R 26
160
(2)x3.3V@4.0A 10.0V@0.1A 10V@0.1A
PoE26W5V-R
26
160
(2)x5.0V@2.6A 10.0V@0.1A 5.0V@0.1A
DCR/
Pri
(ohms)
max
0.100
0.100
0.100
(1) Test parameters: 100 kHz, 0.100 Vrms, 0.0 Adc
(2) DCR limits maximum @ +20 °C
DCR/ DCR/ DCR/ Leakage Pri
Sec
Bias Sync Induct. Current Turns ratio pins Pri (2 - 4):
V1 (12 - 10): V2 (11 - 9):
(ohms) (ohms) (ohms) (uh)
Pk
max
max
max
typ. (Adc)
Bias (1 - 6): Sync (7 - 8)
0.025
0.90
0.42
1.0
2.6
1:0.29:0.29:0.83:0.42 +/-2%
0.025
0.90
0.90
1.0
2.6
1:0.29:0.29:0.83:0.83 +/-2%
0.050
0.90
0.42
1.0
2.6
1:0.42:0.42:0.83:0.42 +/-2%
(3) Leakage Inductance 300 kHz, 0.01 Vrms, 0.0 Adc
Dimensions- mm
SCHEMATIC
12
2
Primary
TOP VIEW
M
FRONT VIEW
12
1
L
1
D
(12 plcs)
PoE
A
J
(12plcs)
E
H
(12 plcs)
7
G
(12 plcs)
F
(2 plcs)
12
Component Side
I
6
Output
RECOMMENDED PCB LAYOUT
White Dot Pin #1
6
B
C
O
(10plcs)
N
(10plcs)
4
10
1
11
Bias
Output
7
K
(12plcs)
9
6
7
Sync
8
DIMENSIONS
A
mm
max.
21.5
B
mm
ref.
22.0
C
mm
max.
28.5
D
mm
ref.
0.7
E
mm
max.
10.8
1) Tolerances A - H are ± 0.25 mm unless specified otherwise.
2) Tolerances I - O are ± 0.10 mm unless specified otherwise
3) All soldering surfaces are coplaner to within ± 0.102 mm.
4) Do not rout traces or vias underneath the transformer
Packaging information- mm
Parts packaged on 13" Diameter reel, 115
parts per reel.
2
www.eaton.com/electronics
F
mm
ref.
2.95
G
mm
ref.
0.1
H
mm
ref.
0.4
I
mm
ref.
17.25
J
mm
2.25
K
mm
3.15
L
mm
ref.
23.2
M
mm
max.
29.5
N
mm
3.0
O
mm
0.75
Technical Data 4081
Effective July 2017
Solder Reflow Profile
TP
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
25°C
Preheat
A
T smax
t
TC -5°C
Table 1 - Standard SnPb Solder (Tc)
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
ts
Package
Thickness
2.5mm
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4081
July 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“POE26W3.3VS5-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 115+71.43365
- 15065+53.22460
- 国内价格 香港价格
- 115+52.50992115+6.78747
- 230+51.74347230+6.68840
- 国内价格 香港价格
- 115+93.21421115+12.04893
- 230+90.27326230+11.66878
- 345+88.59111345+11.45134
- 575+86.51185575+11.18258
- 805+85.16696805+11.00874
- 国内价格 香港价格
- 1+104.316961+13.48408
- 10+94.0964610+12.16297
- 25+90.2523125+11.66607
- 50+87.4368150+11.30214
- 国内价格 香港价格
- 115+90.75155115+11.73060
