CT-1020
CT-1020
    AMGIS
    插件
    CT-1020
CT-1020 数据手册
Page 01/02 Current Transformer dϭϬϮϬ Product Type AMGIS Part Number Customer Part Number Place of Manufacture SCHEMATIC: (K) (L) (2) (1) ELECTRICAL SPECIFICATION: Volt/Amp at rated Ip for different loads Rated input current = 20Amps Primary to Secondary isolation Operating Frequency Turns Ratio DC Resistance Output Voltage Io @ Vrms : 2.65V Ratio Correction factor (RCF*) 100Ω 500Ω 2000Ω 5000Ω = 2500VAC = 50 / 60 Hz 0.10 0.43 0.76 0.93 = 1 : 1000 = 41.80 Ω = 2.0V @ 20A / 100Ω, 0.0400W = 628µArms = 1.01 @ 10% (Multiply current reading by this factor to compensate for transformer losses) MECHANICAL SPECIFICAITON : 23.80 1 7.62 3 2 Front View 11.12 Pin Side View OUTPUT RESPONSE vs INPUT CURRENT @ RATED BURDEN : (L) 23.80 Ø9 .5 (K) 1 3 2 7.62 15.24 5±1 Marking Area 3xØ0.8 All dimensions are in mm Linear dimensional tolerance ±0.2mm Note : Un-Used pin → #3 AMGIS, LLC * 10899 Kinghurst St. Ste. 220 Houston, TX 77099 Phone: 832-775-1319 * Fax: 832-775-1317* email: sales@amgistoroids.com Toll Free: 877-762-6447 * www.amgistoroids.com Page 02/02 TYPICAL EXCITATION CURVE : RATIO ERROR (%) vs RATED BURDEN @ INPUT CURRENT : TRAFO WEIGHT: MARKING INFORMATION: Approx. Weight = 0.0163 kg / pc L01-6213 Ac yr / wk code Dot mark for Start pin identification -----------------Initial Issue----------------Changes 1 Issue 0 Rev Balaji. R Initial AMGIS, LLC * 10899 Kinghurst St. Ste. 220 Houston, TX 77099 Phone: 832-775-1319 * Fax: 832-775-1317* email: sales@amgistoroids.com Toll Free: 877-762-6447 * www.amgistoroids.com 18-Nov'2015 Date
CT-1020 价格&库存
很抱歉,暂时无法提供与“CT-1020”相匹配的价格&库存,您可以联系我们找货
