AS-105
AS-105
    AMGIS
    AS-105
AS-105 数据手册
AS Series • Current Sense Inductors & Transformers AS Series Current Sensors are designed as a low cost method of controlling, monitoring or measuring AC currents. The sensors serve as feedback elements between the output and pulse control circuitry providing accurate regulation of switch mode power supplies. Features • Fully encapsulated for optimal PC board mounting • Frequency range from 20kHz to 200kHz • Primary current rating to 30 Amps • Primary to secondary isolated to 2500 VAC • Meets VDE norms • Optimum performance over designated current and frequency range • Competitive pricing due to high volume production • Manufactured in an ISO-9001:2000, TS-16949:2002 and ISO-14001:2004 certified facility • Fully RoHS compliant Applications Isolated current feed-back signal in Switch Mode Power Supplies • Motor current load/overload • Lighting Switch Controls • Ultra-sound current • High resolution sonar current • Isolated bi-directional current sensor with full wave bridge rectifier Electrical Specifications at 25°C Part Number Prim./Sec. Ratio Lsec (1) (mH Min) DCRsec (Ohms Max.) Sec. Term. (2) Resistance (Ohms Nom.) Isec (3) Max. Volt µS (4) Max. AS-100 1:50 6 0.6 50 300mA 175 AS-101 1:100 25 1.1 100 150mA 350 AS-102 1:200 100 4.5 200 75mA 700 AS-103 1:300 250 10.0 300 50mA 900 AS-104 1:500 700 25.0 500 30mA 1500 AS-105 1:750 1682 43.0 750 40mA 3750 AS-110 1:50CT 6 0.3 / 0.3 25 + 25 300mA 175 AS-111 1:100CT 25 0.55 / 0.55 50 + 50 150mA 350 AS-112 1:200CT 100 2.25 / 2.25 100 + 100 75mA 700 AS-113 1:300CT 250 5.0 / 5.0 150 + 150 50mA 900 AS-114 1:500CT 700 12.5 / 12.5 250 + 250 30mA 1500 AS-115 1:750CT 1682 21.5 / 21.5 375 + 375 40mA 3750 Notes: 1) Lsec: Secondary inductance tested at 10kHz and 10mV for 1:50 through 1:500 2) This nominal termination resistance value will yield approximately 1.0V 1 3 1 2 3 17.2 Prim./Sec. ratios and 1kHz/10mV for Prim./Sec. ratio of 1:750 of output for each amp of current in a single turn sense line. The output 5.0 17.0 3) ASXXX 1 2 F (Hz): Frequency 5) Operating Temperature Range: -40°C to +120°C 6) Pin 2 is on Center-Tapped (CT) versions only 4 .0 6.35 (0.250) maximum primary current of 15 Amp-turns rms while the Isec value for the ratio of 4) 3 0.45 x 0.66 For Prim./Sec. Ratios of 1:50 through 1:500, the sec I value corresponds to a 1:750 corresponds to a max. primary current of 30 Amp-turns rms. 1 VµS = R t x Is x 2F Rt (Ohms): Recommended Terminating Resistance Is (A): Secondary Current 20.4 A0*,6 Voltage/Ampere of these devices can be increased or decreased linearly over a restricted temperature range by adjusting the terminating resistance. Schematic 12.7 + 9.53 1 2 + 3 _ _ Primary Sense Current AMGIS, LLC * 10830 Kinghurst Dr. Houston, TX 77099 Phone: 832-775-1319 * Fax: 281-933-9067* email: sales@amgistoroids.com sales@alfamag.com Toll Free: 877-762-6447 * www.amgistoroids.com AS Series • Current Sense Inductors & Transformers Electrical Specifications at 25°C Part Number Prim./Sec. Ratio Lsec (1) (mHMin.) D C R sec (Ohms Max.) Sec. Term. (2) Resistance (Ohms Nom.) Isec (3) Max. Volt µS (4) Max. Type 1 Type 2 AS-200 AS-300 1:50 5 0.65 50 300mA 175 AS-201 AS-301 1:100 20 1.30 100 150mA 350 AS-202 AS-302 1:200 80 4.50 200 75mA 700 AS-210 AS-310 1:50CT 5 0.65 25 + 25 300mA 175 AS-211 AS-311 1:100CT 20 1.30 50 + 50 150mA 350 AS-212 AS-312 1:200CT 80 4.50 100 + 100 75mA 700 AS-320 1:50 5 0.65 50 300mA 175 AS-321 1:100 20 1.30 100 150mA 350 AS-322 1:200 80 4.50 200 75mA 700 AS-330 1:50CT 5 0.65 25 + 25 300mA 175 AS-331 1:100CT 20 1.30 50 + 50 150mA 350 AS-332 1:200CT 80 4.50 100 + 100 75mA 700 Type 1 14.50 (0.571) 10.15 (0.400) 3 4 1 17.8 (0.700) 12.7 (0.500) 4.0 (0.157) 5 15.25 (0.600) 3 Pins 1 & 2 Ø 1.30 (0.051) 19.60 (0.772) Pins 3, 4 &5 Ø 1.00 (0.039) 2 Pri./Sec. Ratio IP Amps Volt µS Application (Max.) AS-400 1:100 1 350 Switching AS-401 AS-402 1:100 1:100 2 5 550 1500 Switching Switching AS-403 1:100 10 1500 Switching AS-404 AS-405 AS-406 AS-407 1:100 1:500 1:500 1:500 50 50 65 80 1500 2700 4200 7500 Switching Switching Switching Switching 4 5 3 1 4 2 5 1 2 6 7 3 5 1 2 6 7 3 4 5 6 7 1 2 Pins 3, 4 &5 Ø 0.80 (0.032) • Operating Temperature Range: -40°C to +120°C • Primary to secondary isolated to 4000 VAC • Primary current rating to 80 Amps C ase Type Schematic • Dimensions C D E F G H I Hole 7 A 17.8 12.8 20.0 10.0 5.0 15.0 5.0 -- 2 8 A B 23.0 32.5 15.5 18.0 25.0 35.5 12.5 15.0 10.0 12.5 20.0 -- 5.0 -- --- 1 2 3 4 7 A 32.0 20.5 35.0 17.5 12.5 27.5 7.5 -- B A A B 32.5 23.0 27.0 32.5 18.0 15.5 18.0 18.0 35.5 25.0 30.0 35.5 15.0 12.5 15.0 15.0 12.5 10.0 12.5 12.5 -20.0 22.5 -- -5.0 5.0 -- Ø8 Ø5 Ø5 Ø8 1 8 7 8 Type B 5.0 ±0.3 7 8 3 4 H G I 0.60 x 0.88 mm (AS-403 0.75 x 1.10) Pins 1, 2, 6 & 7 Ø 1.30 (0.051) 22.9 17.8 (0.700) (0.902) 3.5 ±0.3 C 4.0 (0.157) 5 Type A E 2 17.8 (0.700) 6.35 (0.250) 12.7 (0.500) Features • Meets requirements of IEC 950 and VDE norms UL94, VO recognized materials • Operating frequency range from 20kHz to 200kHz Electrical Specifications at 25°C Part Number 3 1 Type 2 18.0 (0.709) 5.08 (0.200) Schematic 1 G C 2 F D 0.60 x 0.88 mm E F D AMGIS, LLC * 10830 Kinghurst Dr. Houston, TX 77099 Phone: 832-775-1319 * Fax: 281-933-9067* email: sales@amgistoroids.com Toll Free: 877-762-6447 * www.amgistoroids.com
AS-105
物料型号:文档中列出了多个型号,例如AS-100、AS-101、AS-102等,每个型号具有不同的原边/副边电流比率。
器件简介:AS系列电流传感器是一种低成本的方法,用于控制、监测或测量交流电流。这些传感器作为输出和脉冲控制电路之间的反馈元件,提供开关电源的精确调节。
引脚分配:文档中提到了不同型号的引脚分配,例如Type 1和Type 2的引脚尺寸和布局。
参数特性:包括全封装、频率范围20kHz至200kHz、最大30A的原边电流额定值、原边与副边隔离高达2500V AC等。
功能详解:文档提供了详细的电气规格,如原边/副边比率、副边电感、副边直流电阻、副边终止电阻、最大副边电流和最大输出电压微秒值。
应用信息:应用包括高分辨率声纳电流、开关电源中的隔离电流反馈信号、电机电流负载/过载、照明、开关控制、超声波电流等。
封装信息:文档中提供了不同型号的封装尺寸和类型,例如Type A和Type B的尺寸和孔径。
AS-105 价格&库存
很抱歉,暂时无法提供与“AS-105”相匹配的价格&库存,您可以联系我们找货
AS-105
    • 1+42.630871+5.54098
    • 10+38.5065410+5.00491
    • 25+36.9571425+4.80353
    • 50+35.8214650+4.65592
    • 100+34.71523100+4.51214
    • 250+33.29665250+4.32776
    • 500+32.25622500+4.19253
    • 1000+31.243811000+4.06094
    库存:11
