101990060
101990060
    SEEED(矽递科技)
    ACCURRENTSENSOR15AMAX
101990060 数据手册
Non-invasive AC Current Sensor (15A max) SKU: 101990060 (images/product/101990060 1_02.jpg) Description What is CT sensors Current transformers (CTs) are sensors that are used for measuring alternating current. They are particularly useful for measuring whole building electricity consumption (or generation for that matter). The split core type such as the CT in the picture above, is particularly suitable for DIY use it can be clipped straight on to either the live or neutral wire coming into the building without having to do any high voltage electrical work.     Features      Applications • • • •          Suitable for the current measuring          Monitoring and protection of AC motor          Lighting equipment          Air compressor Specification • • • • • • • • • •          Input Current: 0~15A AC          Output Mode: 0~1V          Non-linearity: ±3%          Build-in sampling resistance(RL): 124Ω          Resistance Grade: Grade B          Work Temperature: -25°C ~ ﹢70°C          Dielectric Strength(between shell and output): 1000V AC/1min 5mA          Leading Wire in Length: 1m          Open Size: 13mm x 13mm          Fire resistance property: in accordance with UL94-VO http://www.seeedstudio.com/depot/Noninvasive-AC-Current-Sensor-15A-max-p-2053.htm... 1/11/2016
101990060
- 物料型号: 101990060 - 器件简介: 该器件是一种非侵入式交流电流传感器,最大测量电流为15A,适用于测量建筑物的总电力消耗或发电。 - 引脚分配: 文档中未提供具体的引脚分配信息。 - 参数特性: - 输入电流: 0~15A AC - 输出模式: 0~1V - 非线性: ±3% - 内置采样电阻(RL): 124Ω - 电阻等级: Grade B - 工作温度: -25°C ~ +70°C - 绝缘强度(外壳与输出之间): 1000V AC/1min 5mA - 导线长度: 1m - 开口尺寸: 13mm x 13mm - 防火性能: 符合UL94-VO标准 - 功能详解: 该传感器适用于交流电流的测量,特别适用于DIY使用,可以夹在进入建筑物的火线或零线上,无需进行高压电气工作。 - 应用信息: 适用于电流测量、监测和保护交流电机、照明设备、空气压缩机等。 - 封装信息: 文档中未提供封装的详细信息,但提到了开口尺寸为13mm x 13mm。
101990060 价格&库存
很抱歉,暂时无法提供与“101990060”相匹配的价格&库存,您可以联系我们找货
