101990064
101990064
    SEEED(矽递科技)
    ACCURRENTSENSOR60AMAX
101990064 数据手册
Product Specification Product Name Current transformer Date:2015-8-7 Model SCT013-060 Characteristics:Openning size 13mm*13mm,1m leading wire, standard Φ3.5 three-core plug output. voltage output type. Purpose: Used for current measurement, monitor and protection for AC motor,lighting equipment, air compressor etc. Patent No.:ZL 2015 3 0060067. X Technical Data IPN Rated input IPM Max. detection input IOUT Rated output 0-1V X Accuracy ±1% εL Linearity ≤0.2% N Turns ratio 1:1800 Φ Phase shift RL Max.Sampling resistance VPN Work voltage f Work frequency TA Operating temperature TS Storage temperature Vd Dielectric strength, 50 Hz, 1 min 0-60A 660V Fire resistance UL94-V0 -25..+70℃ Material of core Ferrite -40..+85℃ Mounting type Suspension Weight 55g 50-1KHz 3KV Dimension ( mm(in). 1 mm= 0.0394 inch) Ip 31(1.22) 13(0.51) 10(0.39) 32(1.26) 13(0.51) Ip output R 3.5mm 34(1.34) 1m 23.5(0.93) Front view empty Vout 11.5(0.45) voltage output type putput (can provide other wiring way) 22(0.87) Side view Schematic diagram http://www.yhdc.com Standard three-core pligs schematic diagram
101990064 价格&库存
很抱歉,暂时无法提供与“101990064”相匹配的价格&库存,您可以联系我们找货
  • 1+63.759091+8.22509
