101990029
101990029
    SEEED(矽递科技)
    NON-INVASIVEACCURRENTSENSOR(
101990029 数据手册
Product Specification Product Name Current transformer Date:2015-8-7 Model SCT013-000 Characteristics:Openning size 13mm*13mm,1m leading wire, standard Φ3.5 three-core plug output. Current output type Purpose:Used for current measurement, monitor and protection for AC motor,lighting equipment, air compressor etc. Patent No.:ZL 2015 3 0060067. X Technical Data IPN Rated input IPM Max. detection input IOUT Rated output X Accuracy ±1% εL Linearity ±3% N Turns ratio 1:1800 Φ Phase shift ≤180' RL Max.Sampling resistance VPN Work voltage f Work frequency TA Operating temperature TS Storage temperature Vd Dielectric strength, 50 Hz, 1 min 0-100A 0-50mA 10Ω 660V Fire resistance UL94-V0 -25..+70℃ Material of core Ferrite -40..+85℃ Mounting type Suspension Weight 55g 50-1KHz 3KV Dimension ( mm(in). 1 mm= 0.0394 inch) 23.5(0.93) Front view 31(1.22) 13(0.51) 10(0.39) Ip 34(1.34) 32(1.26) 13(0.51) 11.5(0.45) output Ip empty 3.5mm TVS Iout 1m putput (can provide other wiring way) current output type 22(0.87) Side view Schematic diagram http://www.yhdc.com Standard three-core pligs schematic diagram
101990029 价格&库存
很抱歉,暂时无法提供与“101990029”相匹配的价格&库存,您可以联系我们找货
  • 1+90.811091+11.80271
库存:474
