CT-1200
CT-1200
    AMGIS
    插件
    CT-1200
CT-1200 数据手册
Current Transformer CT1200 Product Type Amgis Part Number Page 01/02 SCHEMATIC: (K) (L) (2) (1) ELECTRICAL SPECIFICATION: Volt/Amp at rated Ip for different loads Rated input current = 200Amps 100Ω 500Ω 2000Ω 5000Ω = 2500VAC = 50 / 60 Hz 0.10 0.37 0.41 0.45 = 1 : 1000 = 11.00 Ω = 20.0V @ 200A / 100Ω, 4.0000W = 2340 µArms =1.002@10% (Multiply current reading by this factor to compensate for transformer losses) Primary to Secondary isolation Operating Frequency Turns Ratio DC Resistance Output Voltage Io @ Vrms : 22.20V Ratio Correction factor (RCF*) MECHANICAL SPECIFICATION : dŽƉ View (^ƵŐŐĞƐƚĞĚWĂĚ>ĂLJŽƵƚ) 55.60 3 Front View Ø2 3.8 0 20.60 2 1 3xØ1.20 12.70 45.72 55.60 (L) (K) 3xØ1.0 1 3 2 5±1 Marking Area 22.86 All dimensions are in mm Linear dimensional tolerance ±0.2mm Note : Un-Used pin → #3 Amgis LLC • 10899 Kinghurst St. Ste. 220 • Houston, Texas 77099  3KRQH (8) • Fax (832)775-1317 Technical: info@amgistoroids.com • Sales: sales@amgistoroids.com • www.amgistoroids.com Page 02/02 OUTPUT RESPONSE vs INPUT CURRENT @ RATED BURDEN : TYPICAL EXCITATION CURVE : MARKING INFORMATION: TRAFO WEIGHT: Amgis CT1200 Yr/Wk code Approx. Weight = 0.150 kg / pc Dot mark for Start pin identification -----------------Initial Issue----------------Changes 1 Issue 0 Rev K.Shanmugam Initial 01-Dec'2015 Date Amgis LLC • 10899 Kinghurst St. Ste. 220 • Houston, Texas 77099  3KRQH (8) • Fax (832)775-1317 Technical: info@amgistoroids.com • Sales: sales@amgistoroids.com • www.amgistoroids.com
CT-1200 价格&库存
很抱歉,暂时无法提供与“CT-1200”相匹配的价格&库存,您可以联系我们找货
