10/5/22, 9:48 AM
Current Transformer Indoor Toroidal (CT Series) - Hammond Mfg.
Quality Products. Service Excellence.
Current Transformer Indoor Toroidal CT Series
Features
Toroidal design.
Supplied with 24" insulated secondary leads, terminated with crimped ring connectors.
Suitable for use with bare (uninsulated) primary conductor in circuits up to 600 V (4 KV Hi
pot); or at higher voltages when a suitably insulated conductor is used.
All units have 5 A secondary for use with standard AC ammeters with 5 A movements.
Two hole mounting bracket on all models.
UL E227616 volume #1 file number X0DW2
Application Data
To obtain current measurement:
1. Pass the wire carrying the current to be measured through the window of the CT
transformer (acting as a primary winding).
2. Connect the CT secondary to an ammeter with a 5 A movement.
For higher accuracy or higher VA burden rating:
1. Choose a CT with a primary which is a multiple of the required primary rating and which
has the accuracy or VA burden you require.
2. Loop the wire carrying the current to be measured through the window a number of times
equal to the multiple. This "winding" will reduce the ratio back to required primary rating.
Example "A": To obtain an accuracy of 1.2% at 10VA burden with a ratio of 100:5,
use a CT400 and loop 4 primary turns through the window.
Example "B": To obtain a 25:5 ratio, use a CT75 with 3 primary turns to yield 2%
accuracy or a CT50 with 2 primary turns to yield 3.2% accuracy.
Part No.
Current Ratio
Accuracy
Burden
Overall Dimensions
https://www.hammfg.com/electronics/transformers/instrument/ct
Mounting Slots
Ship Wt.
1/2
10/5/22, 9:48 AM
Part No.
Pri. / Sec.
Current
Ratio
Accuracy
VA
Burden
A
B Overall
C Dimensions
D
E
F
G
H
Mounting
Slots
Lb.Wt.
Ship
Pri. / Sec.
VA
A
B
C
D
E
F
G
H
Lb.
CT50A
50:5
3.2
2
3.75
1.75
3.25
3.00
0.87
2.87
0.22
0.37
1.3
CT60A
60:5
2.4
2
3.75
1.75
3.25
3.00
0.87
2.87
0.22
0.37
1.4
CT75A
75:5
2
2
3.75
1.75
3.25
3.00
0.87
2.87
0.22
0.37
1.5
CT100A
100:5
2
2
3.75
1.75
3.25
3.00
1.20
2.87
0.22
0.37
1.1
CT150A
150:5
1.2
2
3.75
1.75
3.25
3.00
1.20
2.87
0.22
0.37
1.4
CT200A
200:5
1.2
2
4.75
1.75
4.25
4.00
2.20
3.87
0.22
0.37
1.7
CT250A
250:5
0.6 - 1.2
2-5
4.75
1.75
4.25
4.00
2.20
3.87
0.22
0.37
1.7
CT300A
300:5
0.6 - 1.2
2 - 10
4.75
1.75
4.25
4.00
2.20
3.87
0.22
0.37
1.8
CT400A
400:5
0.6 - 1.2
2 - 10
4.75
1.75
4.25
4.00
2.20
3.87
0.22
0.37
1.8
CT500A
500:5
0.3 - 1.2
2 - 20
4.75
1.75
4.25
4.00
2.20
3.87
0.22
0.37
1.8
CT600A
600:5
0.3 - 1.2
2 - 20
6.00
1.75
5.25
5.25
3.50
5.12
0.28
0.37
2.5
CT800A
800:5
0.3 - 1.2
5 - 50
6.00
1.75
5.25
5.25
3.50
5.12
0.28
0.37
2.8
CT1000A
1000:5
0.3 - 1.2
5 - 50
7.00
1.75
6.25
6.25
4.50
6.12
0.28
0.37
3.3
CT1200A
1200:5
0.3 - 1.2
10 - 50
8.00
1.75
7.75
7.25
5.50
7.12
0.28
0.37
3.8
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
2/2
很抱歉,暂时无法提供与“CT1200A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1375.526861+177.96112
- 10+1225.0527510+158.49328
- 25+1169.8272025+151.34838
- 50+1129.7363250+146.16155
