CT1000A
CT1000A
    HAMMONDMANUFACTURING
    螺栓安装
    TRANSFORMER TOROID 5-50VA 1000:5
CT1000A 数据手册
10/5/22, 9:48 AM Current Transformer Indoor Toroidal (CT Series) - Hammond Mfg. Quality Products. Service Excellence. Current Transformer Indoor Toroidal CT Series Features Toroidal design. Supplied with 24" insulated secondary leads, terminated with crimped ring connectors. Suitable for use with bare (uninsulated) primary conductor in circuits up to 600 V (4 KV Hi pot); or at higher voltages when a suitably insulated conductor is used. All units have 5 A secondary for use with standard AC ammeters with 5 A movements. Two hole mounting bracket on all models. UL E227616 volume #1 file number X0DW2 Application Data To obtain current measurement: 1. Pass the wire carrying the current to be measured through the window of the CT transformer (acting as a primary winding). 2. Connect the CT secondary to an ammeter with a 5 A movement.   For higher accuracy or higher VA burden rating: 1. Choose a CT with a primary which is a multiple of the required primary rating and which has the accuracy or VA burden you require. 2. Loop the wire carrying the current to be measured through the window a number of times equal to the multiple. This "winding" will reduce the ratio back to required primary rating. Example "A": To obtain an accuracy of 1.2% at 10VA burden with a ratio of 100:5, use a CT400 and loop 4 primary turns through the window. Example "B": To obtain a 25:5 ratio, use a CT75 with 3 primary turns to yield 2% accuracy or a CT50 with 2 primary turns to yield 3.2% accuracy. Part No. Current Ratio Accuracy Burden Overall Dimensions https://www.hammfg.com/electronics/transformers/instrument/ct Mounting Slots Ship Wt. 1/2 10/5/22, 9:48 AM Part No. Current Transformer Indoor Toroidal (CT Series) - Hammond Mfg. Pri. / Sec. Current Ratio % Accuracy VA Burden A B Overall C Dimensions D E F G H Mounting Slots Lb.Wt. Ship Pri. / Sec. % VA A B C D E F G H Lb. CT50A 50:5 3.2 2 3.75 1.75 3.25 3.00 0.87 2.87 0.22 0.37 1.3 CT60A 60:5 2.4 2 3.75 1.75 3.25 3.00 0.87 2.87 0.22 0.37 1.4 CT75A 75:5 2 2 3.75 1.75 3.25 3.00 0.87 2.87 0.22 0.37 1.5 CT100A 100:5 2 2 3.75 1.75 3.25 3.00 1.20 2.87 0.22 0.37 1.1 CT150A 150:5 1.2 2 3.75 1.75 3.25 3.00 1.20 2.87 0.22 0.37 1.4 CT200A 200:5 1.2 2 4.75 1.75 4.25 4.00 2.20 3.87 0.22 0.37 1.7 CT250A 250:5 0.6 - 1.2 2-5 4.75 1.75 4.25 4.00 2.20 3.87 0.22 0.37 1.7 CT300A 300:5 0.6 - 1.2 2 - 10 4.75 1.75 4.25 4.00 2.20 3.87 0.22 0.37 1.8 CT400A 400:5 0.6 - 1.2 2 - 10 4.75 1.75 4.25 4.00 2.20 3.87 0.22 0.37 1.8 CT500A 500:5 0.3 - 1.2 2 - 20 4.75 1.75 4.25 4.00 2.20 3.87 0.22 0.37 1.8 CT600A 600:5 0.3 - 1.2 2 - 20 6.00 1.75 5.25 5.25 3.50 5.12 0.28 0.37 2.5 CT800A 800:5 0.3 - 1.2 5 - 50 6.00 1.75 5.25 5.25 3.50 5.12 0.28 0.37 2.8 CT1000A 1000:5 0.3 - 1.2 5 - 50 7.00 1.75 6.25 6.25 4.50 6.12 0.28 0.37 3.3 CT1200A 1200:5 0.3 - 1.2 10 - 50 8.00 1.75 7.75 7.25 5.50 7.12 0.28 0.37 3.8 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/instrument/ct 2/2
CT1000A 价格&库存
很抱歉,暂时无法提供与“CT1000A”相匹配的价格&库存,您可以联系我们找货
CT1000A
    • 1+1898.40240
    • 200+757.47960
    • 500+732.16440
    • 1000+719.65800
