Product Specification
Product Name
Current transformer
Date:2015-8-7
Model
SCT013-030
Characteristics:Openning size 13mm*13mm,1m leading wire, standard Φ3.5 three-core plug output.
voltage output type.
Purpose:Used for current measurement, monitor and protection for AC motor,lighting equipment, air compressor etc.
Patent No.:ZL 2015 3 0060067. X
Technical Data
IPN
Rated input
IPM
Max. detection input
IOUT
Rated output
0-1V
X
Accuracy
±1%
εL
Linearity
≤0.2%
N
Turns ratio
1:1800
Φ
Phase shift
RL
Max.Sampling resistance
VPN
Work voltage
f
Work frequency
TA
Operating temperature
TS
Storage temperature
Vd
Dielectric strength,
50 Hz, 1 min
0-30A
660V
Fire resistance
UL94-V0
-25..+70℃
Material of core
Ferrite
-40..+85℃
Mounting type
Suspension
Weight
55g
50-1KHz
3KV
Dimension ( mm(in). 1 mm= 0.0394 inch)
Ip
31(1.22)
13(0.51) 10(0.39)
32(1.26)
13(0.51)
Ip
output
R
3.5mm
34(1.34)
1m
23.5(0.93)
Front view
empty
Vout
11.5(0.45)
voltage output type
putput
(can provide other wiring way)
22(0.87)
Side view
Schematic diagram
http://www.yhdc.com
Standard three-core pligs
schematic diagram
很抱歉,暂时无法提供与“101990028”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+87.426611+11.22225
