L01-6364
L01-6364
    AMGIS
    XFRMR TOROIDAL 25VA THRU HOLE
L01-6364 数据手册
L01 Series 50 / 60 Hz PC Mount Toroidal Transformers SCHEMATIC 6 1 PRI1 SEC1 2 3 5 8 PRI2 SEC2 Specifications valid for all types: Input voltage 2x115V, 50/60Hz 0.5KVAC (prim-prim & sec-sec) HV test 4KVAC (prim-sec) Ambient Temperature T 70 ºF Isolation class VDE* F 155 ºC Safety Approval VDE, UL, CE *Refer to next page 7 4 D E 1 2 3 4 A 8 7 6 5 C B *top view DIMENSIONS – L01 SERIES VA RATING L W H A B C D E 1.6 39.60 39.60 18.50 35.56 35.56 25.40 30.48 20.32 3.2 44.70 44.70 19.50 40.64 40.64 30.48 35.56 25.40 5 49.70 49.70 19.50 45.72 45.72 35.56 40.64 30.48 7 49.70 49.70 23.10 45.72 45.72 35.56 40.64 30.48 10 55.00 55.00 26.00 50.80 50.80 40.64 45.72 35.56 15 60.00 60.00 26.30 55.88 55.88 45.72 50.80 40.64 25 60.00 60.00 37.50 55.88 55.88 45.72 50.80 40.64 35 72.00 72.00 37.50 66.04 66.04 55.88 60.96 50.80 50 82.40 82.40 37.50 76.20 76.20 66.04 71.12 60.96 *in mm Amgis LLC • 10899 Kinghurst St. Ste. 220 • Houston, Texas 77099 Phone: 832-775-1319 • Fax (832)775-1317 Technical: info@amgistoroids.com • Sales: sales@amgistoroids.com • www.amgistoroids.com L01 Series 50 / 60 Hz PC Mount Toroidal Transformers 1.6 VA 3.2 VA 5 VA 7 VA 10 VA 15 VA 25 VA 35 VA 50 VA Part Number L01-6300 L01-6301 L01-6302 L01-6303 L01-6304 * L01-6305 2x 2x 2x 2x 2x 2x Secondary 7V 114 mA 9V 89 mA 12V 67 mA 15V 53 mA 18V 44 mA 22V 36 mA No load voltage 2 x 9V 2 x 11.6V 2 x 15.4V 2 x 19.3V 2 x 23.4V 2 x 28.2V Resistance 20°C 2 x 8.80Ω 2 x 15.8Ω 2 x 26.9Ω 2 x 43.4Ω 2 x 65.9Ω 2 x 88.1Ω Weight total = 80 g Weight Cu = 20 g Efficiency = 77% External Fuse 32mA (stb) at 230V Fixing = M4 threaded screw Part Number L01-6310 L01-6311 L01-6312 L01-6313 * L01-6314 * L01-6315 2x 2x 2x 2x 2x 2x Secondary 7V 229 mA 9V 178 mA 12V 133 mA 15V 107 mA 18V 89 mA 22V 73 mA No load voltage 2 x 10.2V 2 x 13.0V 2 x 17.3V 2 x 21.4V 2 x 25.7V 2 x 31.3V Resistance 20°C 2 x 7.0Ω 2 x 11.3Ω 2 x 20.7Ω 2 x 28.9Ω 2 x 45.4Ω 2 x 62.2Ω Weight total = 110 g Weight Cu = 26 g Efficiency = 70% External Fuse 32mA (stb) at 230V Fixing = M4 threaded screw Part Number L01-6320 L01-6321 L01-6322 L01-6323 * L01-6324 * L01-6325 2x 2x 2x 2x 2x 2x Secondary 7V 357 mA 9V 278 mA 12V 208 mA 15V 167 mA 18V 139 mA 22V 114 mA No load voltage 2 x 9.7V 2 x 12.4V 2 x 17.0V 2 x 21.3V 2 x 25.5V 2 x 30.5V Resistance 20°C 2 x 4.0Ω 2 x 6.5Ω 2 x 12.3Ω 2 x 19.0Ω 2 x 28.8Ω 2 x 39.1Ω Weight total = 144 g Weight Cu = 33 g Efficiency = 68% External Fuse 50mA (stb) at 230V Fixing = M4 threaded screw Part Number L01-6330 L01-6331 L01-6332 L01-6333 L01-6334 * L01-6335 2x 2x 2x 2x 2x 2x Secondary 7V 500 mA 9V 389 mA 12V 292 mA 15V 233 mA 18V 194 mA 22V 159 mA No load voltage 2 x 9.5V 2 x 12.2V 2 x 16.2V 2 x 20.3V 2 x 24.3V 2 x 29.7V Resistance 20°C 2 x 2.5Ω 2 x 4.1Ω 2 x 7.7Ω 2 x 12.0Ω 2 x 17.9Ω 2 x 24.4Ω Weight total = 174 g Weight Cu = 36 g Efficiency = 74% External Fuse 63mA (stb) at 230V Fixing = M4 threaded screw Part Number L01-6340 L01-6341 L01-6342 L01-6343 L01-6344 * L01-6345 2x 2x 2x 2x 2x 2x Secondary 7V 714 mA 9V 556 mA 12V 417 mA 15V 333 mA 18V 278 mA 22V 227 mA No load voltage 2 x 8.3V 2 x 10.8V 2 x 14.4V 2 x 18.0V 2 x 21.7V 2 x 26.3V Resistance 20°C 2 x 1.0Ω 2 x 1.7Ω 2 x 3.2Ω 2 x 5.0Ω 2 x 7.5Ω 2 x 10.3Ω Weight total = 252 g Weight Cu = 45 g Efficiency = 82% External Fuse 80mA (stb) at 230V Fixing = M4 threaded screw Part Number L01-6350 L01-6351 L01-6352 L01-6353 L01-6354 * L01-6355 2x 2x 2x 2x 2x 2x Secondary 7V 1071 mA 9V 833 mA 12V 625 mA 15V 500 mA 18V 417 mA 22V 341 mA No load voltage 2 x 8.9V 2 x 11.1V 2 x 14.8V 2 x 18.5V 2 x 22.2V 2 x 27.2V Resistance 20°C 2 x 0.85Ω 2 x 1.3Ω 2 x 2.3Ω 2 x 3.1Ω 2 x 5.3Ω 2 x 7.4Ω Weight total = 304 g Weight Cu = 57 g Efficiency = 80% External Fuse 100mA (stb) at 230V Fixing = M4 threaded screw Part Number L01-6360 L01-6361 L01-6362 L01-6363 L01-6364 * L01-6365 2x 2x 2x 2x 2x 2x Secondary 7V 1785 mA 9V 1377 mA 12V 1041 mA 15V 832 mA 18V 694 mA 22V 568 mA No load voltage 2 x 8.3V 2 x 10.7V 2 x 14.3V 2 x 17.8V 2 x 21.4V 2 x 26.2V Resistance 20°C 2 x 0.4Ω 2 x 0.7Ω 2 x 1.3Ω 2 x 2.0Ω 2 x 2.7Ω 2 x 4.1Ω Weight total = 435 g Weight Cu = 85 g Efficiency = 83% External Fuse 160mA (stb) at 230V Fixing = M4 threaded screw Part Number L01-6370 L01-6371 L01-6372 L01-6373 L01-6374 * L01-6375 2x 2x 2x 2x 2x 2x Secondary 7V 2500 mA 9V 1944 mA 12V 1458 mA 15V 1167 mA 18V 972 mA 22V 795 mA No load voltage 2 x 8.2V 2 x 10.6V 2 x 14.0V 2 x 17.6V 2 x 20.9V 2 x 25.7V Resistance 20°C 2 x 0.19Ω 2 x 0.32Ω 2 x 0.53Ω 2 x 0.84Ω 2 x 1.10Ω 2 x 1.34Ω Weight total = 590 g Weight Cu = 187 g Efficiency = 82% External Fuse 200mA (stb) at 230V Fixing = M5 threaded screw Part Number L01-6380 L01-6381 L01-6382 L01-6383 L01-6384 * L01-6385 2x 2x 2x 2x 2x 2x Secondary 7V 3571 mA 9V 2777 mA 12V 2083 mA 15V 1666 mA 18V 1389 mA 22V 1136 mA No load voltage 2 x 8.1V 2 x 10.4V 2 x 13.9V 2 x 17.3V 2 x 20.8V 2 x 25.4V Resistance 20°C 2 x 0.13Ω 2 x 0.20Ω 2 x 0.34Ω 2 x 0.54Ω 2 x 0.82Ω 2 x 1.25Ω Weight total = 800 g Weight Cu = 209 g Efficiency = 85% External Fuse 315mA (stb) at 230V Fixing = M5 threaded screw * Not Applicable for VDE Amgis LLC • 10899 Kinghurst St. Ste. 220 • Houston, Texas 77099 Phone: 832-775-1319 • Fax (832)775-1317 Technical: info@amgistoroids.com • Sales: sales@amgistoroids.com • www.amgistoroids.com
L01-6364
物料型号:L01系列 器件简介:这是一系列50/60 Hz的PC安装环形变压器,具有不同的额定功率和输出电压选项。 引脚分配:文档中未明确提供引脚分配图,但提供了变压器的尺寸和额定功率。 参数特性:输入电压为2x115V,50/60Hz,高压测试分别为0.5KVAC(原边-原边和副边-副边)和4KVAC(原边-副边)。环境温度为70°F,隔离等级为VDE F 155°C,安全认证包括VDE、UL和CE。 功能详解:文档列出了不同额定功率的变压器的详细规格,包括额定功率、输出电压、空载电压、电阻、重量、效率和外部保险丝规格。 应用信息:文档未明确提供应用信息,但这些变压器通常用于电源转换和电源适配器。 封装信息:提供了变压器的尺寸和安装方式,例如M4螺纹螺丝。
制造商信息:Amgis LLC,位于德克萨斯州休斯顿,提供了联系方式和技术销售邮箱。
L01-6364 价格&库存
很抱歉,暂时无法提供与“L01-6364”相匹配的价格&库存,您可以联系我们找货
