166G36
166G36
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 18VA CHAS MOUNT
166G36 数据手册
www.hammondmfg.com 166G36 Power Transformer - Low Voltage/ Filament Economical Single Primary - Open Style Chassis Mount GRN C B A BLK D Features • Economical single primary 115 VAC, 60 Hz. (or 117 50/60 Hz. see table below) • Open style, channel bracket, chassis mount. • Minimum 6” long leads. • Dual bobbin design - no electrostatic shield required. • Class B insulation (130 degrees, C) for extra protection - UL listed as a Class A (105 degree, C) design • Hi-Pot test of 2,000V RMS. • CSA certified. BLK GRN GRN/ YEL Overall Dimensions (in. / mm) A 3.25 / 82.6 B 1.63 / 41.4 C 2 / 50.8 Schematic Blk Hole to Hole Mounting Dims D Grn 2.81 / 71.4 Mounting Hole Sizes Width-wise 0.187 / 4.7 Depth-wise / Electrical Size (VA) 18 Primary 115V 60 Hz. Secondary VAC 36 C.T. Secondary Amps 0.5 Primary / Grn/ Yel Blk Grn Secondary E
166G36 价格&库存
很抱歉,暂时无法提供与“166G36”相匹配的价格&库存,您可以联系我们找货
166G36
  • 1+267.986471+33.51897
  • 10+241.2582710+30.17589
  • 30+229.3177630+28.68240
  • 50+223.9494250+28.01094
  • 100+216.84179100+27.12194
  • 250+207.75922250+25.98592
库存:59
