166G9
166G9
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 4.5VA CHAS MOUNT
166G9 数据手册
www.hammondmfg.com 166G9 Power Transformer - Low Voltage/ Filament Economical Single Primary - Open Style Chassis Mount GRN C B A BLK D Features • Economical single primary 115 VAC, 60 Hz. (or 117 50/60 Hz. see table below) • Open style, channel bracket, chassis mount. • Minimum 6” long leads. • Dual bobbin design - no electrostatic shield required. • Class B insulation (130 degrees, C) for extra protection - UL listed as a Class A (105 degree, C) design • Hi-Pot test of 2,000V RMS. • CSA certified. BLK GRN GRN/ YEL Overall Dimensions (in. / mm) A 2.38 / 60.5 B 1.38 / 35.1 C 1.38 / 35.1 Schematic Blk Hole to Hole Mounting Dims D Grn 2 / 50.8 Mounting Hole Sizes Width-wise 0.187 / 4.7 Depth-wise / Electrical Size (VA) 4.5 Primary 115V 60 Hz. Secondary VAC 9 C.T. Secondary Amps 0.5 Primary / Grn/ Yel Blk Grn Secondary E
166G9 价格&库存
很抱歉,暂时无法提供与“166G9”相匹配的价格&库存,您可以联系我们找货
166G9
  • 1+240.852651+30.12515
  • 10+216.8367710+27.12132
  • 25+207.8642525+25.99906
  • 50+201.3002650+25.17805
  • 100+194.91837100+24.37983
  • 250+186.76341250+23.35983
  • 500+180.80261500+22.61427
库存:1
